Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Solenoid or Starter?
Old Feb 18, 2008 | 11:09 PM
SixShooterCamaro's Avatar
Hey guys whats up? I just replaced the Fuel Filter on my camaro and it runs smooth, no more sputtering when I hit the gas....
Now heres another problem:
Whenever I try to start the engine all I hear is a clicking noise and it clicks once, it doesnt try to turn over it just kind of clicks and then you try again and it will start with no problem after a couple of times of the clicking sound....
It has a new battery in it so I eliminated that possibility and I figured it be the starter but then it doesnt have trouble starting, So Im thinking either Solenoid or Battery cable terminals....
Anybody know what this may be?
Old Feb 19, 2008 | 09:45 AM
23tigga's Avatar
It sonds like a bad connection I would check for burnt spots on the starter wires and the battery cables. Check for corroision and also make sure the connection is good and tight
Old May 10, 2008 | 12:46 PM
FNDRB58's Avatar
Can you update how you fixed your problem. I have the same issue with my car. Thanks.
Formula Steve
Sep 19, 2023 08:31 AM
marlar98
Sep 19, 2015 07:53 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
350350
14
Aug 11, 2015 12:03 PM
