Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel line ?
Old Jan 17, 2008 | 11:44 AM
a4z28's Avatar
Fuel line ?
I need some help with my fuel system i am running an aeromotive a1000 fuelpump and am making about 650 on motor and going to spray 300 what size line will i need to run . If some one can give me a little chart on an sizes to 1/2 inch size. Something like this Thankyou
6an= ?
8an= ?
10an= ?
Old Jan 17, 2008 | 03:47 PM
Wrong forum... I'll move it to fuel and ignition.
The "AN" size is approx. the line diameter in 16ths of an inch....
-6AN = 6/16 = 3/8"
-8AN = 8/16 = 1/2"
-10AN = 10/16 = 5/8"
I run 800 flywheel HP, including a 300-shot, off -6AN supply and return lines, with the rails running in parallel instead of in series. If you are looking at 950HP, you should be running at least an -8AN supply.
Old Jan 29, 2008 | 01:07 PM
Kevin Blown 95 TA's Avatar
Note that the sizes are the eqivalent of O.D. for a steel hard line.
HectorM52
Jul 30, 2017 11:46 AM
87Aerocoupe
Mar 20, 2015 01:23 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
