Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fixing the troublesome fuel gauge
Old Apr 8, 2008 | 11:11 PM
Crows89RS's Avatar
I posted it in electronics, but no one responded really, despite "ttt's". I'm trying to figure out what GM did to fix the fuel gauges in later camaros and trans ams. Basically, right now, whenever I turn right, it goes down a lot, turn left, it goes up a lot, up, it goes up, down it goes down. I would love to have an actually accurate fuel gauge reading, as the first night I owned the car a year and a half ago, I thought I had 1/8th tank, but, nope, I was empty.
Does anyone know what GM did to fix this problem?
Old Apr 9, 2008 | 03:09 PM
When you turn, start or brake, the fuel moves around in the tank, and the level changes. Sitting still, I think everyone just accepts the fact that full is 15+ gallons, 1/2 is ~5 gallons and 1/4 is about ~1.5 gallons.
Old Apr 9, 2008 | 11:39 PM
Crows89RS's Avatar
I put 5 gallons in my car and it says full. That's the problem. And this problem isn't found on newer LS1's. I just wanted to know what GM did to fix the problem.
Old Apr 10, 2008 | 10:26 AM
If your gauge indicates "F" with only 5 gallons in the tank, it is not typical of the way the gauge works in most of the other 93 and up F-Bodys. It would appear to be a problem peculiar to your car. Mine annoyed me because it indicated the numbers shown in my first post. I spent a lot of time on a calibration chart when the car was still new. Shoebox has a writeup on his gauge, and its basically the same set of numbers. It is not normal for it to read "F" with 5 gallons in the tank.
Old Apr 10, 2008 | 11:06 AM
That problem is not found on LT1 f-bodies, either. Could be wiring, gauge, float assy...
http://shbox.com/1/4th_gen_tech2.html#fuel_gauge
Old Apr 10, 2008 | 11:45 AM
Crows89RS's Avatar
i've changed all of the floating assy, sending unit, etc. when i swapped fuel pumps, didn't change anything. i just wish i had a normal fuel gauge.
Old Apr 10, 2008 | 01:52 PM
You can do the tests described in the link to prove where your trouble lies.
Old Apr 10, 2008 | 02:09 PM
Steve in Seattle's Avatar
Post
It reads full with only 5 gallons?
Either the sender's messed up or your gauge is.
Ave you ever taken the needles off the gauges (installing white face overlay?)
Just a thought... it may just be the needle needs to be popped off and reinstalled.
Old Apr 10, 2008 | 03:21 PM
Crows89RS's Avatar
nah, never taken off the needle or anything.
maybe I should just get a fuel cell? maybe that would have an accurate reading? plus my car will look like it's actually got some *****!!
Garcia5
Jul 7, 2022 06:51 PM
armedtrigger
Feb 24, 2015 08:30 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
ANDYZ28
Dec 29, 2014 09:13 PM
MislMan
Jul 19, 2002 11:41 AM
