Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
running really rich...one light from completly rich
Old Dec 13, 2007 | 11:52 PM
green96ta's Avatar
my mods are listed. besides the a/f ratio gauge, thats like 20rwhp right? my car is running rich, one light from the last on the rich side of my a/f ratio gauge. well anyway....my friend has a 99z with exhaust aftermarket maf and some other minor stuff. the biggest thing is he has 4.56's yes its not a typo. but anyway i can pull him by a car from the start. and this is me half throttling it through 1st to prevent spin. but man when we get up top he gains back to about a half car on me. even with the ratio he has. well maybe its because i have been running rich?? who knows. are there any of my mods that could be causing me to run rich?
also how do you think a 92 or 93 mustang gt with H/C/I and headers would fair against me?
Old Dec 14, 2007 | 08:37 AM
AL SS590 M6's Avatar
Moderator
The obvious answer is the tune. Did this just start? Is your AFR narrow band or wide band?
As far as beating the 'stang??? a buddy has one that I helped him biuld with Trick flow heads and cam with ported intake and all the rest that would beat you easily. Full weight convertible, 5 speed, Nitto DRs, with 3.55 gears and he ran a best of 13.28 @ 107-8.
Old Dec 14, 2007 | 09:16 AM
green96ta's Avatar
cool
this guy doesnt have gears. i ran the 13.5 before the relocation brackets and bushings. i also ran it on that old diff. that was shot. lmao i need to post pics of that thing, its a real trophy. but we will see. the afr is narrow band. well i just had put the afr on. but my fuel pump failed on me not too long ago and i put a 255lph. i think that pump had been failing on me for a while now...i had a miss at high rpm that i couldnt find. that was goin on when i ran the 13.5 also. but i fixed that miss when i put the pump in, but i think its too much for my factory regulator
Old Dec 14, 2007 | 07:24 PM
greenmachinedriver's Avatar
mail order tuners tend to error on the rich side for satey. it could posibly be your fuel pump or regulator. check the fuel pressure with a gauge. narrow band sensors cant tell you a whole lot, on a properly running engine it should switch from rich to lean several times a minute or more.
Jan 5, 2015 07:14 PM
Collector Car
Jan 5, 2015 10:58 AM
cmdeshon
Dec 27, 2014 10:06 AM
MJ_Z28
Aug 7, 2002 07:15 PM
