Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel pressure kept building up after going to zero.
Old Apr 12, 2008 | 06:40 PM
mrmint69's Avatar
I had a leak on my return line for the fuel where it connects at the fuel rail. I tried to drain the fuel pressure down using my fuel pressure gauge. It was at 10 and took a long time to go down to zero. I then removed the gauge from the schrader valve and it was making a hissing sound and appeared to have air and fuel coming out together. It did this for over 5 minutes and went away. I had the return line disconnected at the time so it wasn't coming from the fuel return line. Is this normal and the car had been sitting for 3 hours? It was in the 60's today so could this just be pressure from the fuel tank?
DirtyDaveW
Dec 1, 2016 05:37 PM
Cam's maro
Jan 30, 2015 09:21 PM
Jul 4, 2005 05:00 PM
Burn_Out
Aug 18, 2002 08:49 AM
