Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
94 lt1
Old Feb 5, 2008 | 01:38 PM
23tigga's Avatar
94 lt1
Im having heavy misfire and the car itself seems not to stay running I just changed the opti to a msd the plugs and wires still have life can some1 tell me wuts up
Old Feb 5, 2008 | 04:22 PM
Under what conditions does it misfire.... cold start, warm idle, cruise, WOT, etc.? Does it start OK, or does it take an extended cranking period?
Is the SES light on, or have you had it scanned for codes?
Is the engine stock, or is it modified in any way? Trans type?
Was the MSD a full Opti, or just the cap and rotor?
Have you checked the coil and the IC Module? Have you checked the fuel pressure?
Old Feb 5, 2008 | 05:33 PM
23tigga's Avatar
Once it heats up it starts missing the engine is stock the msd is a whole unit the light comes on sometimes I changed the coil it an extended starting period help!!!!!
Old Feb 5, 2008 | 10:28 PM
mrmint69's Avatar
Get it scanned for the codes and it will probably tell the whole story.
Old Feb 9, 2008 | 02:55 AM
23tigga's Avatar
Okay dudes its a lil better now but I think I need plugs its still not accelerating properly I bought a computer scanner but have no idea on how to count the flashes of the SES light what would be the best plugs to go with the msd opti and how do u know when the map sensor is gone?
Old Feb 9, 2008 | 03:49 PM
Originally Posted by 23tigga
Okay dudes its a lil better now but I think I need plugs. Its still not accelerating properly. I bought a computer scanner but have no idea on how to count the flashes of the SES light. What would be the best plugs to go with the msd opti? And how do u know when the map sensor is gone?
Ouch... add some punctuation
You can not flash the codes on a 94 or newer PCM. If you bought the Actron "scanner" for about $30, all it does is short the ALDL pins, to flash the codes, and the last year that worked on an LT1 was 1993. The box says it works with 94, but it doesn't. You nead a "real" scanner, like an Auto Xray, Scanmaster, etc.
What mods have been done to the engine? That will determine whether you can use the stock heat range plugs, or need something different. The spark plug choice is not dictated by the brand of distributor.
A completely failed MAP sensor will sets a code and turn on the SES light. Simply reading the sensor with a scanner may show whether the readings make any sense. What makes you think the MAP sensor is a problem?
Suggestion:
Add a "signature" with basic info about your car - year, model, engine, tranny and any major mods. That way, people can do a better job of helping you. We know its a 94 LT1, but it would be helpful to know what else has been done to it.
Old Feb 11, 2008 | 09:39 AM
23tigga's Avatar
because i had a 92 camaro and when the map went out i was having some of the same troubles but i just dropped it off at the dealer to be scanned so hopefully i get some answers in to what is going on it runs fine sometimes with a lil miss but saturday it started to rev while i was driving pulled over and it died pushed it home wouldnt start, after about ten minutes it started but there was a puff of white smoke that came from under the hood? what could have happened? i need answers cuz i am leaning to sell it but would like to keep it
Old Feb 11, 2008 | 10:12 AM
23tigga's Avatar
Just talked to the dealership they said that the codes are coming from the ignition module and temp sens does these cause this type of behavior
Old Feb 12, 2008 | 02:20 PM
23tigga's Avatar
Will not installing the air vent hose on the msd opti cause any problems and I placed a piece of cardboard behind my exhaust and started it up and I seen some black like carbon on it some1 fill me in
Old Feb 12, 2008 | 03:47 PM
stopthatman's Avatar
besides checking everything again on your opti install, plugs, wires, i'd get a laptop, download TTS datamaster, get a free log of a run and send it to Bryan at pcmforless.com
changing the MAP sensor is a 3 min job, i'd change it if it's 14 years old it's only $30, and get the replacement seal for it too
Old Feb 18, 2008 | 09:29 AM
23tigga's Avatar
I think i have found the problem. I unplugged the pigtail that connects to the ignition module and when I plugged it back up I noticed that one of the wires had been repaired so i wiggled on it and when i went to crank it it ran fine and hasn't been stalling when i crank it now. But i also noticed that the coil wire is a 7mm instead of an 8mm is this affecting my power? And can anyone give me a list of ways to increase my horses without going into the motor in depth
Old Mar 5, 2008 | 01:30 PM
23tigga's Avatar
Can u put delco wires on a msd opti
Old Mar 5, 2008 | 01:34 PM
2000GTP's Avatar
Yes, it will make no difference.
Old Mar 5, 2008 | 02:50 PM
23tigga's Avatar
So the delco wires are compatible with the msd opti
Old Mar 5, 2008 | 04:56 PM
As long as the Delco wires are the ones with the "Opti" ends intended for the LT1, and they plug into the MSD distributor, they are compatible.
