Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
WHITE spark plugs
Old Mar 21, 2008 | 10:43 PM
Greg88's Avatar
WHITE spark plugs
I've searched and searched and cant find anything. My plugs are really white and I've had some people tell me its because the car is running lean and some people say its from the Car burning coolant. I had the PCM tuned from PCM4LESS. Do you think its the tune, or could it possibly be the O2 sensors. Or do I need to regap the plugs, (i dont know what they are gapped at right now). I have a FI system??
Old Mar 22, 2008 | 06:51 PM
Kevin Blown 95 TA's Avatar
Probably no big deal. If you are worried about being lean, get a dyno tune or check it out with a wideband. Typically, you want the light tan color, but I've seen them white in a good running car depending on the fuel beiing used.
Old Apr 12, 2008 | 09:52 PM
OBE1 95Z28's Avatar
White could also indicate too hot a spark plug. You could drop one heat range.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
