Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
fuel pump pigtail
Old Nov 24, 2007 | 09:51 PM
greenmachinedriver's Avatar
fuel pump pigtail
i was installing my new 12 bolt today and i had planned on replacing the pump while the rear end was out. i got a walbro 255 pum from a freind and it did not come with a new electrical conector and the stock conector is much smaller than the conector on the new pump. where can i get the pigtail for the walbro pump?
95 lt1 camaro
Old Nov 25, 2007 | 06:26 PM
horsesAss97's Avatar
i jst happen to install the same pump in a customers 97 t/a and the car started and then died ever since then i havent been able to hear the fuel pump engauge when i started the car they gave me nothing but the pump and the hardware to install i no clips nada. the car continued to blow the ecu to batt witch is basically sayin there is too much draw for the wire to the pump and back to the computer they are surposed to tell u that u have to up the fuses and or the relay and the wire so now all i get is a click. ithink they are junk
Old Nov 25, 2007 | 10:46 PM
Boosted_Z28's Avatar
Try going here: http://www.racetronix.com/
There is a link on that page to E-mail Racetronix. I would contact them.
Old Nov 25, 2007 | 11:22 PM
thanks for the info guys.
i did a litle online searching last night and found thepart i need at autoperformanceengineering.com. they are a little cheaper than ractronix on the pump, plusthey sell alot of the install parts seperatly. they also carry a direct fit lt1 walbro pump. wish i had seen them sooner i cramed the generic gm pump into my fule pump bucket. i think im just going to order the direct fit an replace the whole thing. im selling the generic gm for $75 shipped. if anyones interested they can save a few bucks.
Old Dec 20, 2007 | 02:42 AM
Racetronix's Avatar
That pump is not as plug & play as you might think plus it does not include many parts which require replacement given the age of these cars. Remember you get what you pay for...
Old Dec 21, 2007 | 10:08 PM
worked great for me no problems at all fit right in and pluged into the factory wiring. came with everything needed.
Old Dec 21, 2007 | 11:23 PM
Racetronix's Avatar
The old dry factory rubber ring does not provide a good seal. We supply a new seal system. Much of the factory in-tank wiring is rotted and the terminals corroded. We supply an upgraded Teflon harness which does not rely on the old factory wiring. We supply these items along with a new flex-tube, updated push-lock fitting, bucket sealant/glue. We supply a new 30 micron filter sock to replace the old factory 70 micron filter sock. A proper 30 micron sock is required by Walbro. $149.99 vs. $115.90 = $34.09. When you add it all up there is more that $34.09 in added value here.
Available from CZ28.com supporting vendors:
Old Dec 22, 2007 | 08:35 AM
Agreed, the Racetronics kit is one of the best available as it comes with all the needed parts and full instructions. In addition, the upgraded plug-n-play wiring harness should be considered as well, as it helps to supply full battery voltage to the new fuel pump.
Old Dec 23, 2007 | 08:32 PM
i have nothing against the ractronix kit it looks to be a very good kit. i just thought i would let cost cosiderate people know where they could get a working kit a little cheaper. my kit came with wiring, a new flex tube, a fule pump sock (not shure what micron), fuel pump o-ring (non factory style, bought factor o-ring for 5.99). so the only extra added value in your kit would be the factoy o-ring $5.99 and the glue, under $5.00which equals $10.99. like i said i got the same thing acomplished for less $$. i someone does not want to worry about finding an o-ring or glue your kit is the way to go. but if someone is willing to do a little leg work of there own the ape kit will save a little $$
Old Jan 3, 2008 | 12:00 AM
Racetronix's Avatar
You failed to recognize the parts we replace / upgrade.
Your kit probably came with an in-line adapter or leads so you would still be relying on the old factory wiring. Much of the factory in-tank wiring is corroded. A search of this forum will also show that there is a common problem with the wiring be burnt and the connectors melted due to long-term arcing. We supply ALL NEW upgraded in-tank wiring.
Your flex tube does not have a new push-lock fitting on it. Chances are the ID is not compatible with the pre-existing connector either.
We supply a proper sized flex-tube with new push-lock adapter and SS Oetiker clamps.
The filter sock's rating is critical to the reliability of the pump. Walbro specifies 30 micron or better. The old Nylon mesh factory sock is 70 micron (no good). Apx. value $7.50
Your kit relies on the old rubber ring on the bottom of the pump which is usually hard and dry from sitting in gas for many years. If it does not seal properly the pump can suck in unfiltered fuel or prevent the bucket from functioning properly. We machine the bottom of the pump and install a new o-ring for good seal.
Everything comes pre-assembled with instructions ready to go.
Old Jan 4, 2008 | 04:46 PM
i retract all previos statements racetronix is king of the fuel pump gods and if you buy your pump anywhere else you are asking for trouble. i am sorry i angerd the almighty fuel pump god.
Old Jan 4, 2008 | 05:02 PM
Racetronix's Avatar
Sarcasm is not required. Just making sure people reading this thread actually know what they are getting. Many people do not bother to educate themselves about the options available. That is why we get a constant flow of e-mail from people asking us to sell them pieces from our kit after they have pulled apart their senders. Sure you can take a chance on saving a few $ but in the bigger scheme of things what do you really save? But then again there are those that will go to great lengths to save enough coinage for a McHappy meal and a six pack.
Old Jan 5, 2008 | 09:07 PM
i do enjoy a good burger and six pack!!
Old Jan 5, 2008 | 10:09 PM
97WS6Pilot's Avatar
Yep, I was one of those people that didn't need a pump but needed some of the internal sending unit wiring pieces. You sent me an email and said that the only way to get the pieces I needed was to buy the whole kit. I guess the internal pieces would not make a big enough profit for you. It really turned me off to your business. When it came time to buy injectors I bought them elsewhere.
Old Jan 5, 2008 | 11:42 PM
Racetronix's Avatar
K, you got you jab in….
Sorry you feel that way. We can understand to a certain degree why. Perhaps most of your misdirected frustration was with the vendor who sold you the pump kit and led you to believe it would be complete with everything you would possibly need?
At this time we do not sell or support certain piece parts to be used with non-Racetronix product. This is mostly a liability and support decision.
Hopefully our web ad and posts will help educate potential customers to the differences between our product and others so that they can avoid the disappointment / shortcomings associated with your purchase.
