Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
starting problems
Old May 7, 2008 | 06:06 PM
bowtiepwr's Avatar
starting problems
>hi all,
well let describe what I've done...
I have a 1994 LT1 with a stock Opti (new), MSD 6AL with timing advance
and coil, new Taylor wires and NGK plugs.
The engine is bored/stroked to 396 and there is a Vortech T-trim.
I put a brand new Optima yellow top and I still need a jump start box to get the car started.
any ideas???
Old May 8, 2008 | 02:43 PM
bowtiepwr's Avatar
>I forgot to mention that the battery is relocated to the trunck and there is an external fuel pump too.
Old May 9, 2008 | 07:38 PM
Brcarz28's Avatar
I had the exact same problem after relocating my battery to the trunk. I ended up adding a large braided ground cable from the body to the engine block, fixed the problem right away. Where are you connecting your negative leads from your battery?
Old May 10, 2008 | 12:11 PM
Appears to be a battery wiring problem... not fuel or ignition. What gage wire did you use to run to the back of the car? Did you run both the red wires that normally attach to the battery to the back?
Old May 11, 2008 | 05:23 AM
bowtiepwr's Avatar
>I got the Taylor battery relocation kit, I had someone install it so I will check it out to see where he connected everything.
thanks for steering me in the right direction.
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
