Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel pump noise
Old May 5, 2008 | 09:15 PM
hey01's Avatar
Fuel pump noise
Hearing the fuel pump is nothing new. But i have noticed it sounds different. if i stick my head down in the hatch I notice it now sounds like the high pitch electric motor sound, i can also hear it from my driver side rear tire.
it reminds me of those chevy trucks you hear go by that sound like an electric car cause the fuel pump is so loud.
car isn't running bad or anything, I just noticed the pump sounds a little different.
Old May 6, 2008 | 12:48 PM
hey01's Avatar
anyones fuel pump change sounds before it died? or am I just hearing things?
Old May 6, 2008 | 02:10 PM
ss.slp.ls1's Avatar
The only way to know the condition of your pump is to hook up a fuel pressure gauge and take readings at KOEO, cranking, idle, and WOT. If all checks out, then you should be fine.
Old May 6, 2008 | 02:15 PM
Don 97 SS's Avatar
The time to worry is when your fuel pump stops making that little whining noise.
Old May 6, 2008 | 02:37 PM
hey01's Avatar
what is KOEO,
and what are acceptable pressures for each of those situations?
Old May 6, 2008 | 02:54 PM
Don 97 SS's Avatar
It has been a while since I messed with mine, but if you hook up a FP gauge with a schrader valve to the port at the rear driver side of the intake manifold where the FP regulator is located you can check it there. FP should be about 45psi or so. From my experience fuel pumps either work or they don't.
Old May 6, 2008 | 03:57 PM
ss.slp.ls1's Avatar
KOEO - Key On Engine Off (turn the key but not all the way, this will prime the pump)
Read this:
http://shbox.com/1/4th_gen_tech2.htm...essure_testing
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
