Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Walbro fuel pump problems
Old Dec 6, 2007 | 01:52 PM
95lt188chevytruck's Avatar
So last night I finally dropped the 383 back into my truck and about a month before I had installed my walbro 255lph pump in my truck. I wired everything up and turned the key to see if the pump was coming on and it wasn't. I am at a loss becuase I am pretty positive I wired it up correctly is there anything special needed to turn this pump on over my stock wiring to the pump? I had a stock corvette pump wired in there before and it worked fine.
Any help would be appreciated.
Thanks,
Freddie
Old Dec 6, 2007 | 01:55 PM
mdacton's Avatar
what kind of truck it is in? I think some of the late 80's trucks the fuel pump was grounded on the frame near the tank....Maybe check that first then check the wires going in with a test light make sure its getting power.
Should work just fine
Old Dec 6, 2007 | 05:08 PM
Well I figured it out a wire that I thought was a ground actually hooked up to my starter and now it turns on wen i turn the key
kaoticcamaross
Feb 17, 2015 03:13 PM
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
ANDYZ28
Dec 29, 2014 09:13 PM
