Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Who knows how to use MSD 6BTM?
Old Mar 6, 2008 | 02:46 PM
mrmint69's Avatar
I am trying to figure out how the 6BTM works. It has settings of 0,1,2&3 so does anyone know how to determine which setting to use. I put up a post about knock that i was getting so im hoping you guys might know. I have Datamaster if this would help to figure it out. Other post below:
https://www.camaroz28.com/forums/sho...d.php?t=586035
Old Mar 6, 2008 | 04:53 PM
http://www.msdignition.com/pdf/6462_add_frm23654.pdf
The 6BTM provides a variable timing retard in relation to the amount of boost occurring. The amount of retard that occurs is controlled with the dash mounted control **** and ranges from 0° -3° per pound of boost. The chart in Figure 2 shows the relation of boost and retard.
As an example, if you have the control **** set at 2° and run a maximum of 6-pounds of boost, the total retard at max boost is 12°
(2 x 6 = 12°).
DataMaster will not show any changes resulting from use of the BTM. The BTM processing is done after the PCM tells the plugs when to fire.
Old Mar 14, 2008 | 09:18 PM
97WS6Pilot's Avatar
Its a perfect box for forced induction. I'm very pleased with it. I set mine at 1.5.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
