Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
ob2 says cant connect to computer mean
Old May 6, 2008 | 12:56 PM
roycontreras8's Avatar
My 1995 camaro z28 has a bad miss and lots of black smoke .I pluged in ob2 at auto zone and it read that, So every one says its a ob1 and its only 40 bucks at the zone and i was talking to the person it the store.I said your ob2 sayed it didnt make connection and he but the plug fits perfect in fitting under dash,he says well you do have the ob2 and my computer is broken needs a bank roll to fix? roycontreras8@aol.com
Old May 6, 2008 | 03:45 PM
2001NBMZ28's Avatar
'95's are obd1 with an obd2 style DLC port. You need an obd1 scanner with an adapter or you can jumper 2 pins from the scanner to 2 pins in the DLC.
Old May 6, 2008 | 03:48 PM
2001NBMZ28's Avatar
Here you go, thanks to shoebox.
http://shbox.com/1/xraycable.jpg
Old May 6, 2008 | 07:23 PM
do you thimk it can be anything else like fuel injectors or dist cap
Old May 6, 2008 | 09:44 PM
You need to do some diagnostics before trying to guess what the problem is. It could be many things.
Your AZ people apparently don't know anything about a 1995 LT1 f-body (not surprising).
Nayr
Mar 3, 2023 08:34 PM
Jeff1904
Jun 5, 2016 05:00 PM
jackpawt883
Sep 10, 2015 08:53 PM
Bxlt1
Sep 10, 2015 08:16 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
