Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Can I use 30lbs Injectors??
Old Mar 17, 2008 | 02:35 PM
978Racing's Avatar
Hi, I keep getting conflicting information for my set up. Need the advice of someone who has been there. My 93 LT1 Has a comp 305 cam. 220-230 duration .510 lift. Custom tune, air intake and flowmaster. My injectors are shot, I want to replace with thirty pounders but some people suggest I stay with 24lbs. I do need good part throttle response, because I run into alot of congested traffic in town. I also have speed density, OBD I , not mass airflow. Would like to go with 30lb, but don't want additional tuning problems.
Old Mar 17, 2008 | 02:38 PM
dangalla's Avatar
without getting a tune you can not change injector size
Old Mar 18, 2008 | 10:48 AM
mzgp5x's Avatar
I ran 30# injectors on a 97 LT1. A hypertech tune, but, no adjustment to the injector constant calibration. It ran rich @ first, but, ran good after the PCM adjusted the BLM's. At that time, I ran a P600B Procharger and an FMU. The spike in fuel rail pressure would cause the stock injector pintel to be forced closed @ approximately 90 psi. It was difficult to adjust the FMU. I've since moved on to a 383 - D1 set-up with 72# peak & hold Seimens injectors. I use LT1_edit version 2.2. Hope this helps. B.
Old Mar 18, 2008 | 12:43 PM
978Racing's Avatar
Yes, I will get a re-tune, I just want it to run well after that. Not drowning in fuel.
Old Mar 18, 2008 | 12:45 PM
978Racing's Avatar
WOW! Thats like light years ahead of me! Thanks
13qtr
Oct 28, 2016 08:11 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
