Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel Pressure?
Old May 13, 2008 | 11:44 AM
CrashnBurn's Avatar
Fuel Pressure?
mods in sig....all fresh....whats a good starting point on my fuel pressure
Old May 14, 2008 | 12:04 AM
Stock... 43.5psi, measured with the vacuum compensation line disconnected. Leave it there.
There is no reason to run at anything other than stock, unless you want to increase the effective flow rating of the injectors. When you had the PCM tuned, what pressure did you tell the tuner you were going to run the fuel system at? If you didn't tell him a pressure, he will have assumed you are running stock pressure, and set the injectdor flow constant based on that pressure.
Old May 14, 2008 | 02:37 AM
CrashnBurn's Avatar
Thank you
Ill double check with thunder....it was at least 6 months back so im not sure....car SHOULD finally be running or at least started for the first time tomorrow....or today seeing as how its 230 am
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
