PDA
View Full Version : Fuel and Ignition
Pages : 1 2 3 4 [5] 6 7 8 9 10
  1. Pontiac Timing Issues
  2. 700+rwhp fuel system
  3. Mallory 685 on 97 Z28, cant connect to coil
  4. Fuel pump or relay??
  5. best plug wires to withstand heat?
  6. Fuel Cell
  7. Engine backfires and does not want to start
  8. DELTEQ, Any updates?
  9. 95 z28 fire problem
  10. Injectors at 110 DC
  11. Backfiring
  12. #7 and #8 cylinders running cold?
  13. Those with SLP Shorties on LT1 + Stock Plug Wires..
  14. No Fuel Pressure diagnostic help inside please.
  15. TRE pump in place of stock one
  16. Too big injectors?
  17. TPI Air Intake Hose
  18. rained hard, killed my starter, now bogging down
  19. lowering of fuel pressure
  20. 95 LT1 fuel pump electrical connector
  21. Are plug wires supposed to look like this?
  22. high idle please help
  23. Which Plug Wires Fit in "Stock" Location
  24. LT1 Miss Fire
  25. MSD ignition coil harness for LT1??
  26. Fuel Pump
  27. Ford injectors?
  28. Anyone ever ran a Hollet Innilerator
  29. Is there ANY WAY that this is possible?
  30. fuel problem
  31. Rough time starting and running poor.
  32. Msd wires
  33. Small line hanging over my rear driver axle(fuel?)
  34. engine warm no start condition
  35. confused to whats going on
  36. No Fire, Need Quick Help
  37. Need 60# Fuel Injectors
  38. 1996 Lt1 Coil test?
  39. Racetronix Part Confirmation?
  40. just got done installing my dual intank fuel pumps!!
  41. Finally Running Right...was the ICM :)
  42. possible vac leak
  43. Walbro or Racetronix?
  44. high idle
  45. Fuel Shut Off@ High RPM Until I Let Off Thtottle 95 Z28
  46. Slight stumble off idle.
  47. That p1351 icm code help please
  48. Ebay 10.2mm plug wires.
  49. No Start FIXED!
  50. Fuel pump relay?
  51. corvette injectors in camaro motor
  52. injector orings
  53. MSD 8226 differences
  54. bad misfire and back fire
  55. Fuel line pinhole leak / Replacement
  56. 64psi fuel pressure after dual pump install...do I need an adjustable regulator?
  57. Help, mass airflow sensor
  58. Misfire #2 coil pack plz help!
  59. So what are the limits of a 255 Racetronix w/Hot Wire Kit?
  60. Rough Idle, Possible O2 sensors?
  61. walbro fuel pump problem
  62. Starting Issue / Voltage
  63. Car running rough and shutting off
  64. fuel pressure quickly falls to zero
  65. Should I change my plugs and wires?
  66. Replaced Opti,timing chain, plugs/wires, coil, icm. Car STILL stumbles on face
  67. Lucas injectors too short
  68. pressure build up in fuel tank
  69. HELP!! What would cause an injector to stick open??
  70. dtc 41 no start
  71. Erratic Sparking
  72. Is there a write up for changing out the fuel pump?
  73. fuel pump check valve or fpr
  74. Replace Pump and Filter, and/or Regulator?
  75. Fuel Pump Bucket - Use or no?
  76. MSD ignition misfire on 94 LT1
  77. fuel system issue
  78. no crank
  79. opti-spark internal parts
  80. wiring impedance converters
  81. Couple Ques with Big Fuel system
  82. need help with plug choice
  83. Fuel Pump "Trap Door" Tips + Convertable
  84. New Member - Opti Rant
  85. lt1 sheet metal intake
  86. headers installed and now motor won't start
  87. [parts wanted content deleted]
  88. 95' Z28 Coil
  89. Crank sensor prob plz help
  90. wires and plugs?
  91. Just changed fuel pump and fuel gauge is now off.
  92. tach install
  93. my gas needle is stuck on full
  94. Factory high timing tune?
  95. fuel pump needed
  96. Fuel Pressure probs, won't start
  97. LS1 coils going bad?
  98. LS2 coil boot/terminal p/n number and crimping tool
  99. Ignition ?
  100. I plan to install flow matched injectors rebuilt in Cumming GA.
  101. 32 lb
  102. Unknown Problem with z28... Seems to be fuel or ignition. Any ideas?
  103. 96Z Fuel Pressure Proble
  104. Anyone familiar with GM fuel pump modules? Venturi pump Q.
  105. fuel pressurse help'''
  106. Conventional Billet distributor install in LT1
  107. Car has no power
  108. DELTEQ, how hard is it to build your own Opti Box?
  109. Max Fuel Pressure From Stock Pump
  110. Rusty Fuel tank
  111. Is Aftermarket Fuel Pump Wiring Really Needed?
  112. whats best opti?
  113. Injector #1 not firing at idle
  114. Autometer Fuel Pressure Gauge Problems
  115. Help Chose My Fuel Pump - 383 LE2
  116. What Can Stock 95Z28 Fuel Pump Handle?
  117. Fuel Pump 97Z28
  118. Spark plug gap
  119. Are these fuel pressure readings ok with my 383 ???
  120. Need some help guys...car will NOT fire!
  121. Lt1 Bogging/bucking at low rpm....running rich PLEASE HELP
  122. making spark plug wires
  123. Misfire + black spark plugs on one side
  124. rapid fuel pressure drop
  125. 93 fuel pressure regulator location
  126. LT1 Losing power at high RPM
  127. what is the best stock replacement fuel pump?
  128. Fuel pressure bleed down.
  129. Good place to buy a new GM fuel pump??
  130. Fuel Pressure Test ?'s
  131. slow start, does not fire right off 3800 camaro
  132. 93 z28 fuel schrader valvle
  133. 383 LT1 with SC Injector ?
  134. Ran out of gas, now slow cold start...??
  135. Spark plug help
  136. L76 swap into 97 SS.
  137. Fuel Gauge errors, Hesitation/Surge/Stall..
  138. Aftermarket starter left gap in flywheel housing
  139. Opti install help.
  140. Long term fuel trim question......
  141. question about leaking injector or w.e it is??
  142. HOw do i removing ignition cylinder from my 1978 camaro z28
  143. Demon tuning problems, need some major help.
  144. IAC Test
  145. TPI Plenum Box
  146. where can I get these parts im missing? Walbro install
  147. fuel pump
  148. LT1 fuel lines
  149. idle
  150. opti vent lines
  151. adjustable fuel pressure regulator
  152. Fuel cooling
  153. gas tank removal
  154. LT1 Fuel Line Questions?
  155. i need help plz
  156. fuel smell
  157. need helps guys
  158. fuel or ignition
  159. 1994 Z28 Runs and Quits Randomly
  160. i need plz quick
  161. mefi3 or 4
  162. air fuel ratio gauge?
  163. 94z28 Fuel leaking out of vent valve from tank?
  164. Bad gasoline?
  165. Dash light problem
  166. Alternate place for electric fuel press. sending unit?
  167. Car hesitating to start Sometimes
  168. Car hesitating, don't know why
  169. new ignition lock cylinder
  170. GMS fuel pump
  171. Wich wire and plug gap for ltcc install
  172. Opti disappointment
  173. fuel injector question
  174. Car won't start: BAD VATS/Passkey bypass -> Fuel System problem!!!!
  175. Delteq ignition system?
  176. Boost gauge wiring problems
  177. Autolite AR 135 Spark Plugs?
  178. AN fittings on fuel rails
  179. in-line fuel booster ?
  180. LT1 vs. LS1 steel fuel lines
  181. Fuel line removal...
  182. Injector Rebuilds
  183. ignition problem... please help
  184. Key Won't Turn
  185. Fuel guage problem
  186. Faulty fuel pressure regulator ????
  187. Mass-Flo fuel injection
  188. Lost power
  189. Car died while driving
  190. Racetronix Fuel Pump issues
  191. what kind of fuel pressure regulator?
  192. All-Ignition Dragonfire Distributor(Opti-Spark)
  193. need help
  194. Urgent help needed with racetronix fuel pump install
  195. Starts and quits randomly.
  196. Need help whats this part???
  197. Fuel pump bucket
  198. No start, new ignition parts
  199. Ignition problem
  200. ? about stainless steel being a good conductor
  201. Hard start at way lower elevation
  202. Opti Problem
  203. Stumble+Backfire under moderate to heavy load, please help
  204. Prob starting
  205. throttle body plate
  206. impediance converters?
  207. Plastic retainer clips on the stock fuel lines
  208. slow start
  209. Backfirng
  210. Cranks but won't start..please help
  211. Vapor vent hose on fuel pump
  212. Do I need aftermarket adjustable pressure regulator
  213. Fuel Pressure at WOT
  214. Loud grinding noise when turning ignition
  215. 60# injectors?
  216. fuel pressure guage
  217. i need to be edu. on GM injectors
  218. i have 2002 3.8 V6 camaro and want to step up the injectors
  219. OHM Test plug wires ?
  220. Crank no start help please
  221. question about starting problem im having.
  222. hose adapters
  223. MSD cap & rotor..what else to get while im down there?
  224. help picking injectors?
  225. opti on ebay
  226. Missing
  227. fuel gauge
  228. Parallel Fuel System... Pressure Problem
  229. Need help with fuel problem
  230. Throttle Body
  231. No Spark on my 92 v-6
  232. Help? Low idle and low fuel pressure
  233. help please?
  234. Digital or analog fp gauge
  235. Car wont start!
  236. rough idle and slight miss?!
  237. Possible fouled plugs
  238. HELP!!! MSD6AL problems!
  239. fuel line for 800hp?
  240. Help !!!!!!!!!!!!!!
  241. LT1 Injectors
  242. What are these Fuel lines?
  243. plugwire Side Mounts
  244. Which Lines at the Fuel Pump are the return, etc.?
  245. Remote disconnect for battery
  246. Fuel Gauge Not Reading correctly.
  247. New Ignition Coil = Car Reborn
  248. Access Hole
  249. pressure guage adapter
  250. Opti ate me baby!!!
