Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
fuel pump change and best pump?
Old Dec 31, 2007 | 06:45 PM
evanbrendel's Avatar
i have a 98 camaro and i have saw a guy named scoter in town change a fuel pump if his ta by cutting the floor out over the pump is this the easyist way to do it or is it easy to drop the tank? if i do drop the tank do i have to drop the axle? also what is the best pump to go with for me and what all do i need i run 150 n2o going to headers and exhauste and tune 410 gears. 6 speed car. ran fine with 150 shot but i dont kno if headers will make a difference or if the fuel pump may get weak.
Old Jan 1, 2008 | 09:44 AM
AL SS590 M6's Avatar
Moderator
With the exhaust out of the way the tank comes out pretty easily.
I went with the Racetronixs fuel pump kit. It includes a ''hot wire'' kit, Walbro pump, and everything necessary to do the install.
Old Jan 16, 2008 | 11:44 AM
MeFast's Avatar
I did mine on monday.I have some pics if you need them .
Old Jan 16, 2008 | 03:25 PM
KingJames's Avatar
^What pump did you use to do your install?
Old Jan 20, 2008 | 10:27 AM
MeFast's Avatar
I used walbro 255 that i got from EPP.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
Scottyboy
Feb 11, 2015 10:28 PM
ANDYZ28
Dec 29, 2014 09:13 PM
Jul 4, 2005 05:00 PM
