Guaging interest: burn my own chips or ed wright
Old Sep 2, 2002 | 10:14 PM
Beast87GTA's Avatar
Lightbulb Guaging interest: burn my own chips or ed wright
Allright, first of all this is what i have: an 87 gta that has trickflow heads, lt4 hotcam, slp 1 3/4 headers (shorties), 24 lb. injectors, 1.5 rr's, 3 inch catback, miniram intake manifold, 3.23's, beefed up 700r4, a 350 bored 30 over, 10.5 to 1 compression, and a fastchip from ed wrights company. With all that it's not running near what it should. It's a little quicker than stock lt1 but i'm possitive with that setup it should be much quicker. So i want to konw what yall think. I have to decide if i think i should take it up to Ed Wright in Oklahoma and have him tune it for $500 or if i should buy the burning equipment for $250 and do it myself. I know ed wright would do wonders for my car but i don't have $500 right now. But i have enough for the chip burning stuff. I think that i could burn the chips and i know my dad probably could too(he is really good with cars, he helped me build my whole engine). But Ed Wright is one of the best. So i'm asking yall what you think i could do. Any suggestions would be great! Thanks Jake
Old Sep 2, 2002 | 10:42 PM
Stephen 87 IROC's Avatar
Post
How many chips are you going to burn before you get the setup right?
At least with Ed's chip, if it isn't right he'll just burn you another one.
I bought one for my truck. I had problems with it from day one. He burned another one for me and sent it right out the next day. Best service I've seen and it's worked fine ever since.
Stephen's racing page
or check out the race car
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.349
Best MPH on a time slip: 119.7
Best corrected ET: 10.983
Altitude corrected rear wheel HP: 480
Best 60 foot: 1.546
Member of the Calgary Drag Racing Association
Old Sep 3, 2002 | 01:29 AM
aklim's Avatar
Post
I went with www.fasterproms.com and found them to be the best I have worked with.
They give you a chip based on your mods, take diacom readings and reburn it till it is on the money. After that, they will charge you $500. In the future, when you make significant changes to your setup where you need it reburnt, it costs $150 and we repeat the same datalogging experience. Beyond that, another place that is good is Lingenfelter Perf. Engr. They will want your car for a couple of weeks and get it so it works.
With fasterproms you don't have to leave your home except to do datalogging runs.
Burning chips is not so simple as to turn a switch off or on. Knowledge is expensive. I wouldn't buy a "one size fits all" chip from Jegs or Summit because they don't do squat.
You can save a lot of money in the long run if you burn it yourself. HOWEVER, how often do you have to burn chips? If you get it right, not very often. In the last 6 years, I have needed 2 burns. The first one was when I switched to a 383 with 30pph injectors and the second was when I had to rebuild my 383 because of TFS heads and I swithched to 24pph injectors. 2 sets of burns in 6 years. The only thing I need to reburn for is if I went to a blower or NO2. My 383 is at 10.8:1 compression so I cn't go that route. The only other thing I can think of is if I changed my induction system or a cam. Since I am not doint it that often, I guess the DIY approach does not benifit me.
Last thing, either go to Ed, have him send you stuff to datalog or forget it. Without datalogging, it is a shot in the dark.
Old Sep 3, 2002 | 01:32 AM
Z_Ghost's Avatar
Post
I have been playing with the chips on my Z for about a year now and I like doing it. I can say that I have the Z running better than the factory had it.
I will see how good I am when I start burring chips for the B4C that I am building up right now.
It does take time and lots of testing to get the chip right, but if you add anymore parts to the car later you will need to get it tuned again.
92 B4C
92 Z/28
Hotchkis,Bilstein,AGR,Wonder bar.
K&N,airfoil.Alum drive shaft,MSD6AL,Ported Plenum
Simmons 17x9.5 275x40x17 FZ50
60'1.937-1/8 8.839-1/4 13.851-98.16 mph
working on chip #22
Moderator: www.lastgen.com, www.gmperformance.org
Old Sep 3, 2002 | 01:51 AM
RedIrocZ-28's Avatar
Post
I have been burning chips for about a month or 2 now. I have had a little success. I dropped .7 in the 1/4 and gained 3+ mph with one chip I burned. If you want the motor to work at its full potential, Ed Wright can get it damn close. If you want it perfect, I would advocate doing it yourself. I know aklim is a diehard Ed Wright fan but I guarantee if he were to burn his own chips he would be able to get the calibrations MORE correct than they already are.
I vote for doing it yourself. You will need the Pocket Programmer II, a UV light eraser, a laptop and a cable either built by you or a $95 cable from AKM electronics. Thats the setup you need. I have it already and I love to be able to log data and make changes and see how the car reacts to it.
Just for a reference, I had my stock chip on the motor in the sig and ran a 14.4 @ 94 on a 2.2 60' and then a 14.4 @ 96 on a 2.08 60'. A few weeks later I ran a 13.7 @ 99.3 on a 1.878 60' with a chip called the ARAP.bin. That ARAP.bin was a file put on the chips that were put in the magazine cars in 1989. As you can see I gained a lot of mph and a lot of ET with just a factory chip in effect. Now to REALLY start modifying it.
-Brad C?
355ci '89 Iroc-Z Red, T-tops, power everything, A4,New 10 bolt w/ 3.73's
Trans-Go shift kit Corvette Servo,Accel 8.8mm wires,Flowmaster 80 series ,K&N's, !MAF Screens, Hollowed out airboxes,homemade Subframes. Kieth Black pistons 10.3:1, Comp Cams 270H (.495/.502 218*/224* 110*LSA) & valve springs, SLP 1 3/4" headers, TCI 2400 stall, Dual Roller timing chain, 2 3/4" I-pipe.
Full street trim best run:14.799/mph:93/60': 2.02 (last year) New Times to come.
New times: 13.732 @ 99.30 on a 1.878 60'
Pics of the Iroc
Old Sep 3, 2002 | 07:47 PM
Zepher's Avatar
Post
You don't need a UV eraser if you use the EEProms since they are electronically erasable with the Programmer.
For the TPI cars, I use the 29C256 eeproms. Takes about 5-10 seconds to erase.
You can build a cable for datalogging for about $10.00 since you only need to have 2 or 3 wires hooked to the ALDL connector.
Basically splice in a DB 9 connector to the 2 or 3 wires and have a DB9 to DB9 cable to hook up to the laptop.
1986 Trans Am WS6
LT4 350, LT4 Hot Cam, T56, 52mm TB, MSD 6A & Blaster 3 Coil,
LT1 3.42 Posi/Disc Rear, Lakewood LCA's & Adjustable Panhard Bar,
Eibach Lowering Springs, 17x9 WS6 Wheels, T-Tops,
Custom 4" CAI w/ K&N Filter, 160*stat, NOS 200hp Fogger System,
Autometer TriplePod with Phantom A/F & Boost Gauges.
High Speed Run: 157mph
Best 1/4 mile run: 14.94@91.67mph This was with the LG4 carb setup.
WS6 Trans Am.
Old Sep 3, 2002 | 10:48 PM
85_tpi_350's Avatar
Post
Unless you're good with cars and better with computers, I'd bite the bullet and have a pro do it.
Horsepower is like cheese, you can add it to ANYTHING and it's a little more enjoyable.
-Posey
Old Sep 4, 2002 | 12:26 PM
aklim's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by RedIrocZ-28:
I know aklim is a diehard Ed Wright fan but I guarantee if he were to burn his own chips he would be able to get the calibrations MORE correct than they already are.</font>
No, I am a fan of www.fasterproms.com or www.lingenfelter.com and the only reason I am more hesitant on LPE is that he needs the car at his facility for a couple of weeks. Fasterproms can do it without the car there.
IndyZman
Oct 22, 2015 02:17 PM
92_RS_305
Sep 8, 2015 07:47 PM
Slayer
Aug 17, 2015 03:55 PM
alphaauto
Jul 26, 2015 04:40 PM
whitehooptie
Jul 22, 2015 10:25 PM
