What is needed for 95' Z wheels on 90' Formula?
Old Aug 27, 2002 | 09:18 PM
SNEAKY NEIL's Avatar
Post What is needed for 95' Z wheels on 90' Formula?
So what exactly is needed for these wheels to fit on the car? I tried it and needless to say, it didn't work. Thanks.
Old Aug 28, 2002 | 01:50 AM
90rsMustangkiller's Avatar
Post
You need wheel spacers, go to www.thirdgen.org and search for wheel spacers. I think they run about 400$ but im not sure. the guys over there will have links to websites where you can order them threw, hope this helps
90 rs 305 tbi, Crane cam, comp roller rockers, vortec heads/high rise intake, Ported, TBI w/350 injectors, and all tbi goddies, custom computer chip, tpi computer, 700r4 rebuilt w/shift kit, b&M megashifter, K&N 14x4 open element, 4 3/4" cowl hood, Edelbrock TES headers, flowmasters, 3.23 posi 383 in the works/ B&M th400 trans
Old Aug 28, 2002 | 05:42 AM
Chvywolf's Avatar
Post
Try www.skulte.com
That is the adaptors I use. 2 1/4 inch in the front and 2 in the back.
89 RS Convertible
Moderator SEThirdgen
Old Aug 28, 2002 | 10:03 AM
IROC5.7TPI's Avatar
Post
FWIW- I think those rims will look fugly on a 3rd gen. 4th gen guys can't seem to give those rims away, let alone justifying the cost of $300 spacers. I would stick with what you got if I were you, but I'm not and its your car so do what you want with it. Just my $.02
Mike L.
1987 IROC Z 5.7 TPI A4 3.27 Borg-Warner four wheel disc
Mods:
2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified airbox w/ K&N's, Relocated MAT sensor, Gutted MAF, 160* thermostat, MSD 6A, Accel 8mm Wires, bypassed TB coolant, 3" Flowmaster 3 chamber single outlet, custom adjustable cutout, 3" MAC mandrel intermediate, airfoil, ported plenum. !smog, Crane AFPR, Accel rail mounted FP gauge, Harlan shiftlite, 24lb. injectors, Hedman headers, a few others I forgot...??? FINALLY GOT PAINT!!
Check out my IROC webpage!
Old Aug 28, 2002 | 11:24 AM
Post
Well, the reason for this is because the wheels on the Formula are in pretty bad shape not to mention that I really don't like the look of them at all, sorry guys. I just wanted to see what they look like but I think that I will not seeing as the spacers are a lot more than I thought.
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
