A funny noise when I punch it??
Old Aug 27, 2002 | 06:20 PM
bigdave8301's Avatar
Question A funny noise when I punch it??
Yet another problem in the pages of my '89 Formula's history...It's a 350 TPI, and not to brag, but when I punch it the front end tries to shoot for the horizon, but it makes a really odd sound when it does it. Right when I crack down on it, it makes an odd drumming sound...It's fast at first, but as my RPMs get higher, it slows down and gets louder until right before it shifts, and then it starts doing it fast again until my RPMs climb. It does it in every gear when I'm hammering it, and the steering wheel and shifter vibrate noticeably too. My buddies told me it might be my torque converter or my bellhousing, and said it felt unbalanced, but I'd like to get some opinions on here first.
Old Aug 27, 2002 | 06:53 PM
Markolc's Avatar
Post
Imbalanced driveshaft and/or Broken tranny mount...Check for both (the tranny mount being easiest).
1987 Flame Metallic Red IROC-Z Camaro. LT1 motor installed. http://home.attbi.com/~markolc
Old Aug 27, 2002 | 10:59 PM
BadIroc's Avatar
Wink
That noise is just your tires melting the pavement as your ripping through gears I'd bet on the tranny mount, when mine went my console and dash would shake like it was in an earthquake it was so bad so if anything i think the tranny mount.
1988 Camaro IROCZ "MIDNIGHT CRUIZERS"
305 ci Tuned Port 700R4
3"Exhaust/Flowmaster 80 series muffler/Dynomax high flow cat/CutOut
hypertech chip/k&n filers, cut MAF screen gutted air box
"Theres no replacement for displacement"
My Iroc web page....
www.geocities.com/bobfitz82/index.html
Old Aug 27, 2002 | 11:16 PM
Question
I thought it was the tranny mount too, so I changed it a couple weeks ago and it kept doing it.
Old Aug 28, 2002 | 01:32 AM
aklim's Avatar
Post
What about the rubber bushing at the end of the torque arm? That or the engine mounts?
Old Aug 28, 2002 | 01:07 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Post
I agree it wouldnt be a bad idea to check the engine mounts I mean if your engine is strong ebough to yank you front tires like that it would surely rock the whole car if it came loose
Old Aug 28, 2002 | 04:11 PM
1fastformula's Avatar
Question
Is it like a fluttering sound??? How how is your timing set?? Could be that you are detonating due to timing being high,bad gas, or engine temps. I had a helluva time trying to figure it out on mine, but once I did NO MORE NOISE!!!
Later
1989 Formula 350
K&N air filter, air foil, TB Bypass, AFPR (set at 45 psi), A.I.R. yanked out, Accel 8mm wires, Fireball external coil, Pulley (just the crank), gutted MAF, corvette servo, Hooker super comp. shorties, 3" exhaust all the way back, No cats, Flowmaster 40 series muffler (one in one out turned down)---Developed a bad habit....bottle related!!!!75 Shot of Nitrous
http://www.theformulasource.com/owne...php?siteid=144
So they made him get rid of it...For decency ya know....But it came back the next day...
My webpage:www.cardomain.com/id/1fastformula
Old Aug 29, 2002 | 10:02 PM
phoenix916's Avatar
Post
It could possibly be the front universal joint starting to go. Not positive but it's worth a shot.
autoxr166
Sep 25, 2015 04:21 PM
Wart Hog
Sep 8, 2015 05:53 AM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
colts0455
Jul 7, 2015 07:19 PM
