proper way to hardwire fan?
Old Aug 29, 2002 | 06:31 PM
ratdog's Avatar
Question proper way to hardwire fan?
i just read that today the very last camaro ever to be made came off the assembly line,gm said that more people are driving suv's.........huh,kind of made me sad.ahhhhh f*** em we all know whats up,hahaha anyway does anyone know the proper way to hardwire my single motor fan to my ignition?on an 84 z28
Old Aug 29, 2002 | 07:42 PM
AutoRoc's Avatar
Post
I had a friend of mine wire my stock dual fans to a switch in my car. Ignition isn't a good idea really because on the highway, the fans aren't needed at all. and they pull a LOT of power! If you had your fans on, AC at full blast, headlights on, and a powerfull radio, you might have some charging problems. I have problems with all that minus the radio part(at lower engine speeds anyways). The stock relay can be used in line with the switch also. Goodluck! Doing that and a 180 thermostat will keep that engine as cool as can be even on a 100 degree day in traffic!@
Denny Villemure
1989 Camaro IROC-Z Convertible, 305 TPI, 2.73 Gear, Flowmaster 2 chamber. 15.60 on motor, 14.20 on a 75 shot from NX. Woo hoo!
www.denny.cz28.com
Old Aug 30, 2002 | 06:18 AM
IrocSS85's Avatar
Post
I had a man. sw. only for a while and let me tell you thats not the way to go. I forgot to turn it on more then a few times. cause you dont want it on whenthe eng. is cold cause that would prolong warmup and Id just forget to turn it on sometimes.
so i recomend a auto-control fan sw. from summit. mine was around $25 or so so they arent exp. you need about 6 feet of 10 gauge wire, an inline fuse, a relay to control the fan, a toggle sw. to control the relay and a auto-control sw. to also turn on the fans when it reaches the temp you set it at.
that is how I have it on mine now and it rocks. my car stays between 180 and 170 now all by itself. and when Im at the track, I can still turn it on to cool the eng. between runs.
chris
MikeWhitener
Aug 2, 2015 06:17 PM
4586
Aug 2, 2015 01:45 PM
Jmj93z28
Jul 8, 2015 10:01 PM
Jmj93z28
Jul 8, 2015 06:58 AM
4586
Apr 27, 2015 06:08 AM
