Busted Gas tank
Old Aug 26, 2002 | 01:08 AM
KarmaCult's Avatar
Question Busted Gas tank
Yup, The neck of my gas tank broke clean off at the actual tank, its still 'in' the tank, and can be used to fill up, but the neck wobbles, and leaks when the car is parked on a hill....
Its pretty much how it should be, nothings sagging, nothings wierd, its just broke in a clean circle around where the neck goes into the tank.
What do I do?
+=-KarmaCult-=+
Old Aug 26, 2002 | 07:44 AM
Randy92Z's Avatar
Post
You'll have to buy a new one. I also need one so Ive been checking this very subject out, here's what Ive found. The dealer (here in Minnesota) wants $415.73 for a new tank for a 92 Camaro (dont know what you have) and the part number is 10269091. If you know someone at the dealer who can get it for you, your cost is 311.80. I called Checker auto (Kragen in CA I think) and they want $202.00 for a tank, with a 2 week wait for it. I also asked about the 1LE baffled tank option and both the dealer and Checker had no option listed for a baffled tank or 1LE option. Hope that helps.
Convertible W/L98, Mini-ram, ZZ9 cam, TPIS 52mm TB, Comp Cams 1.52/1.6 steel roler rockers, Trick flow 23* heads, K&N's with chopped airboxes, Edelbrock ceramic TES, Flowmaster cat-back, Dynomax high flow converter, Accel 300+ ignition, Fastchips custom chip, Taylor pro 409 wires, March underdrive pulleys, MAC subframe connectors, Lakewood LCA & Adj. panhard rod, SLP 2500 stall, 3.42 rear gear, 90 Corvette rims, White face gagues, and NOS!
Old Aug 26, 2002 | 08:02 AM
KarmaCult's Avatar
Post
Damn, I was sorta wanting a quick fix....
The car isn't really worth that right now, but I don't want to blow up half way down the highway....
Old Aug 26, 2002 | 01:17 PM
91RS5speed's Avatar
Post
There is some puddy junk you can put around the neck. It will seal the leak and make it solid agian. I had to do this to mine about 4 months ago and it's still holding up.
http://bitchincamaro.no-ip.com 91 RS Camaro 5-speed black w/t-tops 305 TPI
MODS: SLP cold air intake w/K&N, air foil,Accel 19 LB injectors, March aluminum under drive pullies, Alburn pro posi, Aluminum drive shaft, Random Technology 3'' cat-back, 8.5mm MSD wires, 160 thermo, jet fan swich, Custom chip with 91 vette computer, SSBC slotted rotors, optima battery in the rear, BMR adjustable lower control arms and panhard rod, Kenny Brown strut tower brace, TB bypass, no egr, no air
Old Aug 26, 2002 | 06:10 PM
Scott_92RS's Avatar
Post
Goto www.rockauto.com, they have a cheap tank for around $130 I think, and 2 day shipping is like 30 bucks. Thats the one I'll be purchasing soon.
[This message has been edited by Scott_92RS (edited August 26, 2002).]
Old Aug 26, 2002 | 08:23 PM
Damon's Avatar
Post
There might be a cheap fix, besides the putty. When replacing gas tanks on these cars it's difficult to get the tank out fo the car without bending the filler neck, sometimes breaking it. I have heard some mechanics actually cut off the neck and install a flexible piece of tubing down near where the neck meets the tank. I'm not sure if this is an aftermarket piece or where to buy it, but I bet if you ask around you find someone who can clue you in on it. Good luck.
Old Aug 26, 2002 | 09:26 PM
IrocSS85's Avatar
Post
naw, I did that to my tank and you need to do it about half way up the neck. his broke at the tank flush. and all yo do id cut in half, then add a piece of 2.5" rubber line that fuel compatable.
but I have a tank thats in perfect shape for $50 plus shipping. email me your shipping address and I'll see how much shipping will be. chris
1986 Iroc Z
355, ported camel hump heads,750 holley, 700r4, 10.5 compr., forged flat tops, solidcam .501I .510E, 4gen rear w/3:73 posi, girdle, and disc's, Edel. torker II, shift kit, 3500 stal, hedmann LT. headers, 4 gen seats, man. strg., lt1 starter, alum. w/p, msd 6al, coil, dist., mallory wires.13.34 @102mph best w/that combo. have trick flow heads and tighter conv. to put in currently.
1995 z28,SS Hood, Iroc style spoiler, tints and black outs, 700r4,2400 act. stall speed,B&M hammer shifter, 17" budnick trilogy III wheels, 275/40 ZR17, 160 stat, man. cooling fan sw., homemaid CAI,1LE elbow, hypertech airfoil, t.b.bypass,!cat, flowmaster, !maf screen, relocated batt., 1LE front l.c.a.s', poly trans and torq.arm bushings, MSD 6AL, custom program, p&p maf, accel coil, and under drive pulley
mods that i have, just not on car yet:
msd wires, edelbrock mid. headers, edelbrock rpm catback
Old Aug 26, 2002 | 10:05 PM
KarmaCult's Avatar
Post
Unfortunatly I must wait until the first to do anything, and even then its a maybe, unfortunatly I'm a student on a tight budget, I will look for the puddy stuff, and if all else fails, I can just pull one from the junk yards around town.
There seems to be a black thin 'seal' that is on the neck right now, I figure thats what you are all talking about, but it wasn't put on right, and its chipping away really easy, I figure thats why it broke.
Does ayone have any urls to gas tank articles, so I can learn abit more before I rip my heat shield and muffler, and pretty much the back part of my car off?
I sorta need to know what to expect.
Thanks ^_^
+=-KarmaCult-=+
Pwilson59
Sep 3, 2015 08:47 PM
Strick
Aug 31, 2015 11:45 AM
350350
14
Aug 11, 2015 12:03 PM
Alibi
Aug 1, 2015 07:50 PM
Anon
Jul 23, 2015 12:18 PM
