vortech head question
Old Sep 6, 2002 | 07:17 AM
blueirocz-28's Avatar
Post vortech head question
i know i've gotta get the SA rocker arms. My cam has under .45 lift. can i use stock length pushrods and 1.6:1 ratio rocker arms? or should i just stick with 1.5:1?
Tyler Parsons
'85 IROC-Z
'94 Camaro 3.4L -160 degree stat, throttlebody bypass
Old Sep 6, 2002 | 09:56 AM
pcolaIROC's Avatar
Post
i'm guessing that is a .450"lift?? you could use 1.6rr's, they would only put you at .480 about. and you could use the stock springs too if that's all the cam your using. i still have my vortecs for sale!
Old Sep 6, 2002 | 10:02 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Post
Sure you can try using the 1.6 ratio rocker arms, but make sure you check valve spring clearance. The retainers will hit the valve guides anywhere from .450" to .480" lift.
1991 Camaro Z28
350 L98 w/ T56 (originally 305 LB9 w/ T5)
318 RWHP, 419 RWTQ
12.803 @ 108.50 MPH (1.932 60')
Member: SoCal F-Bodies
ThirdGen 4-Life!
Old Sep 6, 2002 | 10:34 PM
Post
well at my local auto zone, the guy i usually deal with revealed that he was building a 327 with all the vortech goodies. so he's going to hook me up with his brand new roller rockers for about 150, edelbrock rpm airgap intake for 200 bucks. all this stuff is still in its box. this engine is gonna be running very soon.
Tyler Parsons
'85 IROC-Z
oldschool
Feb 9, 2016 09:21 PM
onefastgta
Mar 19, 2015 10:10 AM
LT14LIFE
Feb 9, 2015 09:35 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Brent94Z
Mar 21, 2002 04:44 PM
