92 305TBI to 89 350 TPI, what do I do about the speedometer?
Old Aug 30, 2002 | 06:03 AM
john-e-boy's Avatar
Post 92 305TBI to 89 350 TPI, what do I do about the speedometer?
I am in the middle of converting my 92 RS from a 305 TBI to a 89 350 TPI and I know I need to take the engine harness and computer.
well I am stuck at the speedometer, My 92 has an ecectronic speedometer and the 89 has a manual. If I change the harness and the computer that takes away the wiring for the electronic speedo.
What do I do about that??
Please help
John
Old Aug 30, 2002 | 10:09 AM
91RS5speed's Avatar
Post
Leave the old wiring in. You can remove the old comcoputer though. I just put a corvette computer in my engine bay since it's water proff. Leave all the wires on the inside. All your gages will still work. You want have a check engine light unless u run a wire from the new computer to that light.
http://bitchincamaro.no-ip.com 91 RS Camaro 5-speed black w/t-tops 305 TPI
MODS: SLP cold air intake w/K&N, air foil,Accel 19 LB injectors, March aluminum under drive pullies, Alburn pro posi, Aluminum drive shaft, Random Technology 3'' cat-back, 8.5mm MSD wires, 160 thermo, jet fan swich, Custom chip with 91 vette computer, SSBC slotted rotors, optima battery in the rear, BMR adjustable lower control arms and panhard rod, Kenny Brown strut tower brace, TB bypass, no egr, no air
Old Aug 31, 2002 | 02:14 AM
slimdawson's Avatar
Post
Is swapping the tranny from the 305 to the 350 not an option?
If not, some company makes a signal converter but I am not sure what the name is. Try the search feature, you may find something.
Pix of my rides!
Finally have some pictures of Y2k Vette wheels, motor, etc.
*1991 Camaro RS !LO3
8.65@84.3mph NA
*1988 Mustang 5.0 7.92@87 NA- For Sale
*1988 Mustang GT 'vert
9.56@73-bone stock
*1986 Kawasaki Ninja 1000R 7.30@100mph
*1987 Honda CRX Si 16.5@85mph-stock
100% American!
G-BODYT56
Jan 14, 2022 11:14 PM
HAWG
Sep 25, 2015 11:41 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
