Please help, car will not run.
Old Aug 25, 2002 | 11:53 AM
eej's Avatar
eej
Post Please help, car will not run.
OK it's an 88 305 tbi firebird. The entire distributor is new. The coil is good. the map sensor, temperature sensors, iac valve , are new. Fuel filter is new. The alternator is new. The egr has been blocked off and vacuume lines plugged.
Problem is it does not want to stay running, when i go to start it it will rev up and down until it finally shuts off unless if give it fuel, which it will then try stay running. I have noticed that when the engine dies the injectors are still putting fuel to the engine. So i suspect that it is ignition related. But the basic stuff is all new.
Old Aug 25, 2002 | 12:56 PM
GMTech's Avatar
Post
Take some carburator cleaner and spray it down the throttle body and see if it stays running. It sounds to me like the fuel pump is dead. Just because the injectors spray, doesn't mean there is adequate fuel. Checking fuel pressure on these cars is a PITA because there is not service port. You have to by an inline adapter, just to hook a gauge up to. Stock pressure is usually between 9-13 PSI. Cars that have less than that run like you describe.
Webmaster:SETHIRDGEN
GM Tech
ASE Master Auto Technician + L1
1987 Trans Am: 357ci
Ported TFS heads, ZZ4 cam, headers & exhuast and other go fast goodies
13.53 @ 103.77
Old Aug 25, 2002 | 03:55 PM
eej's Avatar
eej
Post
Uhm am i supposed to be able to hear the fuel pump running with the ignition turned? Not starting it but just turned to the 'run' position? Cause if it's supposed to it's not running. Althought the car will start and stall out.
I replaced the fuel pump relay and no go.
Old Aug 25, 2002 | 06:16 PM
GMTech's Avatar
Post
Sometimes you can hear them, sometimes not. If it didn't work at all (not running) it wouldn't even start and stall. It would just plain not start. It sounds to me like the pump runs, just doesn't put out enough volume to keep the car running.
GM Tech
13.53 @ 103.77
Old Aug 25, 2002 | 09:28 PM
eej's Avatar
eej
Unhappy
Thanks for the help. It's looking like the pump now. Checked spark...it's nice and bright at the plugs. I guess the pump is barely working. I'll be taking it to a mechanic. I really don't feel like doing this job myself. I know it's not hard but it's time consuming and a pain. It's easier for me to just pay to have it done.
jayblev95
Jan 20, 2015 01:30 PM
1775.Z28
Jan 11, 2015 10:51 AM
USAirman93
Nov 24, 2014 03:37 PM
RedLineRev
Jan 23, 2003 03:51 PM
XtremeLt1
Aug 1, 2002 11:25 AM
