Am I Being Anal? Catalytic Converter Question
Old Sep 12, 2002 | 08:34 PM
Christopher's Avatar
Angry Am I Being ****? Catalytic Converter Question
Am I being **** or do people just not pay any attention to what they are doing? I took my car into the muffler shop to replace a catalytic converter that was damaged by a tire shop while backing the car of the lift. This same tire shop put the wheels in the wrong position and could not find a broken anti rattle clip after three brake inspections in one month. Anyway, The guys at the muffler shop had a good laugh at how inattentive they were at the tire shop. They put the new cat on and told me to make sure that I raise hell with the guys at the tire shop. I went to the tire shop, showed them the damaged converter, and receipt. They then reimbursed me for the full amount of repairs. On the way home I also noticed what sounded like a small exhaust leak around the converter area. So when I got home I put it up on the ramps and looked at the cat and there is a BIG ARROW POINTING THE WRONG WAY! Is it asking to much that people just take a look at what they are doing? Now do I tell them to turn the thing around while fixing the leaks? It is a “Catco” converter. Also since I have duel cats should I have them replace the other one while they are at it? I realize I’ll have to pay for the second one. I’m just wondering if there is that much more difference in flow. I’m getting pretty frustrated with the shops in this area.
91 Z-28 1LE
305,5spd
White
Flowmaster
K&N filters
JET Airfoil
<http://www.picturecd.com/system/login.cgi?username=cyetter&album=91+Z28+1LE>
98 Chev Silverado Ext Cab 4x4
Green
Dual Flowmasters
K&N air filter
B&M Shift Plus
Old Sep 12, 2002 | 08:40 PM
91RS5speed's Avatar
Post
Dont let them get away with that crap. You didnt pay them your hard earned money to mess your **** up.
http://bitchincamaro.no-ip.com 91 RS Camaro 5-speed black w/t-tops 305 TPI
MODS: SLP cold air intake w/K&N, air foil,Accel 19 LB injectors, March aluminum under drive pullies, Alburn pro posi, Aluminum drive shaft, Random Technology 3'' cat-back, 8.5mm MSD wires, 160 thermo, jet fan swich, Custom chip with 91 vette computer, SSBC slotted rotors, optima battery in the rear, BMR adjustable lower control arms and panhard rod, Kenny Brown strut tower brace, TB bypass, no egr, no air
Old Sep 13, 2002 | 12:15 AM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Post
This is exactly why I try to do anything that I can myself, Ive never ran across a shop that wasnt crooked in one way or another.
I find your lack of faith disturbing
86 IROC .040 305 TPI
#186 Heads shaved .040 1.98 valves
Shorty Headers 3 in exhaust with Flowmaster
Lunati 259/271 .500/.515 cam
Highly Modified 700-R4
B&M Slapshifter
3.55 Posi Rear
Accel Plugs and Wires
Petronix Flamethrower Distributor
Cragar 15x7 front 15x10 rear
Old Sep 13, 2002 | 12:21 AM
92BLKL98's Avatar
Post
Sorry to those of you who are good professional auto mechanics, but it seems that you can't get good work done anymore some of these so-called ASE mechanics wouldn't make good bicycle techs. I've had some of the same problems, when the mechanic found out I was an airline A&P mechanic they said they always had problems with us. Said we were too **** about our cars, SORRY boys we just want our cars maintained right. We pay you our hard earned money, Damn-it earn it. DO the job right the first time. Don't make us waste our time on return trips, nor your shop's or your reputation. A sign I once read in an auto parts store said "Why is there always enough time to do a job twice but never enough time to do it right the first time". Very true. If you work in a shop as an ASE or even non rated mechanic be a professional be attentive to others property, treat it as if your wife or girlfriend was gonna drive it, I treat Delta's airplanes that way.
92BLKL98
'92 Black Z28 Hardtop w/Harwood 2" cowl ind. hood, Modded 700R4, MSD
Ignition, March Underdrives, TPIS Fastpak, Ram air w/gutted filter box, SLP Prom, Flowmaster, & free mods, removed cats, Amsoil synthetic lubes, CE SFC's, Edelbrock STB,Spohn TA,Roadtech LCA's and Panhard Rod, Energy Susp., PST polygraphite bushings, KYB Shocks.
[This message has been edited by 92BLKL98 (edited September 13, 2002).]
Old Sep 13, 2002 | 07:55 AM
Sciguyjim's Avatar
Post
I agree with you guys. I'd raise he** if my car was treated like that. The only person who can do the job the way you like is you. For those of us who can't we have to watch the shops very carefully. I am one of these so I only go to shops which let me watch the work being done. If I have questions or spot something not right I question it on the spot. I also don't drive away without first looking over the general work area for damages or misfitting parts. Once you drive away it's harder for you to come back and prove they did the damage.
Old Sep 13, 2002 | 10:19 AM
Post
Well, I try to do as much as I can as far as maintaining my vehicles. Unfortunately I do not have acces to a tire machine or welder. But that is not the point. These guys seem to be charging more and more everytime you go there and the quality of service continues to get worse. One shouldn't have to watch over these guys while they are doing the simplest of tasks. Sadley though it seems like I'm going to have to raise some hell today.
Update: Went to muffler shop. They flipped the converter around and offered to replace the other one for $100. So now I have two high flow converters installed for $100. Good deal. Also went to the local oil and lube place and they let me down in the pit to grease the shift fork, ball stud thing that started sqeaking again. while down there they went ahead and greased the rest of the car. All for $5. Turned out to be a pretty good day.
[This message has been edited by Christopher (edited September 13, 2002).]
Old Sep 13, 2002 | 07:00 PM
stanghunter211's Avatar
Post
Heres another exhaust ***** up for the arhcives.
So I have a cutout put on the other day. Works great and sounds the same. But my passenger in the back is complaining that I have hot seats? so I say WTF? Get under the car and look and the retards pointed the opening toward the floorpan, and its heating it up like a **** around town. Freeway its alright. So I go back and they tell me theres nothing they can, that they gave me such a good deal on it that they can't afford to fix it. So I had a flange with it, and asked if I could have a small piece of 45 degree angle pipe welded to the small flange to si can bolt that up and direct the heat away. They say sure..... that will be 65 dollars. I was like you mother *****ers. 65 dollars right when I had the god dam thing installed for 30? So I burned out in the middle of the garage and left. Looks like I will have to rig up a heat sheild of some sort. What azzholes. I swear. Amen about those ASE dudes too, they suck man. No one does quality work, and the ones that do are guys that are like 70 years old and charge enough because they know they can get it. Well, sorry for the rant, just my gripe for the day! Take it easy guys!
Will
'86 Z-28 305 c.i. LG4 165 hp E.T. 16.7 @ 82 mph on radials
Rochester QuadraJet 4bbl,
Flowmaster 80 series, Chrome Tips,
Dual Snorkel Air Cleaner,
K&N Filter,
Michellin P215/65/R15 X-Radial Plus,
Pioneer 4"x6" dash,
Pioneer 6"x9" rear,
Alpine 8" Type S in bandpass box,
MTX Thunder 4202 Amp,
Sony 4000X- x-Plode Deck 50w x4
Soon to be sporting a 350 HO somg legal conversion kit. 308 hp Along with Edelbrock Headers, Edelbrock Performer EGR Intake, and 3" Flowmaster Exhaust with DMH Electric Cutout!!!
ChrisFrez
Feb 15, 2015 07:49 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
86ZZ4
Aug 22, 2002 08:50 AM
Geoff Chadwick
Jul 31, 2002 12:07 PM
