What brands available for fan switch?
Old Aug 25, 2002 | 09:20 PM
whiteminqua's Avatar
Post What brands available for fan switch?
I have been reading posts here for some time, and just registered today. I know this has been discussed before, but I am looking for a vendor or brand name (even GM part number if available) for a cooling fan switch to turn on my fan at 200 deg or so and off at 180 or a little higher. I have just purchased my 180 deg thermostat, a new sending unit for the gage, flush, antifreeze, gasket, and whatever.... What switch do you recommend? What prices are typical? Does GM sell one in this heat range? Thanks. Jess
Oh yeah, I have a new trans cooler to install too.
Blue '86 IROC, 305 TPI
Ported Plenum, gutted air boxes, FastChip, KN filters, TB Airfoil... more to come. Not raced yet. 70,000 original miles. Owned since 1992.
Old Aug 25, 2002 | 11:07 PM
Willie's Avatar
Post
Here's an article I wrote on this very issue:
http://www.thirdgen.org/newdesign/tech/cool.shtml
Once you've read it, shoot me an e-mail if you want specifics.
Willie
Moderator
History/Restoration Board
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
ATI D1SC w/custom Twin Intercoolers.
Best E/T: 12.00
Best Trap Speed: 117.69 mph
SC Z!!!
1987 "20th Anniversary Commemorative Edition" Z28 Convertible
305 TPI / 5-speed
Super Chevy Show Class Winner, 1998.
TPLS Z!!!
Old Aug 27, 2002 | 03:28 PM
Post
Thanks for the info Willie.
Jess
Old Aug 27, 2002 | 04:13 PM
91RS5speed's Avatar
Post
Summit sells a jet fan swich that turns on at 195 and cuts off at 185 for 40-50 bucks. Got one on mine works great.
www.summitracing.com
http://bitchincamaro.no-ip.com 91 RS Camaro 5-speed black w/t-tops 305 TPI
MODS: SLP cold air intake w/K&N, air foil,Accel 19 LB injectors, March aluminum under drive pullies, Alburn pro posi, Aluminum drive shaft, Random Technology 3'' cat-back, 8.5mm MSD wires, 160 thermo, jet fan swich, Custom chip with 91 vette computer, SSBC slotted rotors, optima battery in the rear, BMR adjustable lower control arms and panhard rod, Kenny Brown strut tower brace, TB bypass, no egr, no air
Old Aug 28, 2002 | 01:25 AM
aklim's Avatar
Post
I thought that there was a GM fan switch that did the same thing as the hypertech and others? Anybody know what the part number is?
Old Aug 30, 2002 | 03:55 PM
Post
Thanks for the info, I bought the Hypertech switch for $39.99 at A & A Auto. They had it in stock. Jess
Ported Plenum, gutted air boxes, SuperChip, KN filters, TB Airfoil, transmission cooler... more to come. Not raced yet. 70,000 original miles. Owned since 1992.
Old Aug 30, 2002 | 10:06 PM
Rage's Avatar
Post
Do what I did. Wire up your own fan switch for $2.99. It works just as good, go to the autoparts store, get a switch, wire it from you battary to the switch, the hot wire from the fan to the switch, then run the ground to a bolt somewhere, and then run it to your ACC. It works great. Just takes some time because you have to map it out yourself.
Blue 87 IROC-Z Camaro,305 TPI
3" Flowmaster
Old Aug 31, 2002 | 11:00 AM
Post
Thanks for the info. I got the Hypertech unit for $39.99 at A & A Auto Parts. Now all I need is a spare Saturday to flush the system and install some stuff. Jess
cristian1311
Nov 23, 2014 02:22 PM
Rich_z28
Sep 13, 2002 03:35 PM
troywg
Sep 12, 2002 07:28 PM
Rich_z28
Sep 8, 2002 12:00 AM
96 TA
Sep 1, 2002 02:48 PM
