Anyone ever try to lower your car and it sits higher???
Old Sep 9, 2002 | 11:08 PM
amc91z's Avatar
Post Anyone ever try to lower your car and it sits higher???
I just put on the Hotchkis (sp?) lowering springs on my 91 and the front end sits alot higher...the back looks the same as it did before! Anyone have any ideas why???
Thanks,
Adam
White 91 Z-28:
Currntly a 305 TPI w/auto car. Y2K Corvette Wheels...looks SWEET
Mods:
Comp Cam, ported plenum and runners, AFPR, air foil, 4.11 gears, Hedman Hedders, and a few other goodies...soon to have an LS1 and 6-speed!!!
Old Sep 10, 2002 | 05:21 PM
amc91z's Avatar
Post
Anyone???
White 91 Z-28:
Mods:
Old Sep 10, 2002 | 10:22 PM
Rage's Avatar
Post
Your old springs were probably wore out bro. And when you put new ones on here that were'nt so compressed, it appears to be higher, although lower than the stock stance. Just my .0001 cents.
Old Sep 10, 2002 | 10:34 PM
RedL98Z's Avatar
Post
correct me if i'm wrong, but doesn't it take a week or 2 for the springs to settle? should take a little while for the springs to lower the car...
1991 Z28.L98.700R4
Old Sep 11, 2002 | 11:09 AM
84406's Avatar
Post
It is possible that the coils are not sitting in the upper buckets correctly.
Bob
Old Sep 15, 2002 | 06:48 PM
Marc 85Z28's Avatar
Do the top of the front springs seat into the rubber correctly? Did you make sure to seat the springs properly into the lower control arms? The top doesn't matter, but the bottom does. The end of the coil must sit in the depression in the LCA. It should have 2 small holes which the end of the coil should be between.
The rear must be rotated so the last 180 degrees of the coil is pointed towards the rear. The cut on the end should be facing towards the front.
Besides, they will settle a little after some driving.
Old Sep 20, 2002 | 11:20 AM
91-RED-WS6's Avatar
1991 Z28.L98.700R4
Yep. Hotchkis springs are also a little on the poor side of quality control so some kits may lower 1" on a car, but another car with the same kit could be 1 1/2", etc.
Should have checked before the install, but make sure the p/n# on the boxes is the same p/n# that you ordered. Sometimes the company you ordered from may have mixed 'em up.
Old Sep 20, 2002 | 10:09 PM
Timberwolf's Avatar
you sure you got those black rubber things on the bottom? they can't be on the top or that will screw it all up.
Trying to remember what they are called...
dammit...them black round things, they HAVE to eb on the bottom...
Oh yeah... the TIRES!!! Those have to be on the bottom or else you did it wrong!
Old Sep 21, 2002 | 05:12 AM
TJS69's Avatar
Talking
I am a first gen. owner and I was told that your lower control arms need to be loose and then tightened back up with all the weight of the car on the ground. Not in the air. You might want to try this - not sure if it works.
Old Sep 22, 2002 | 02:30 PM
ebmiller88's Avatar
Here's what you need to check.
First, you need to make sure you have the springs sitting correctly in the upper buckets, fully seated in the ring.
Second, you need to make sure you have them indexed right in the A-arm bucket. The end of the spring needs to be located between or around the 2 drain holes in the arm.
You have to tighten up the bolts after the car is sitting back on it's wheels, too, with the suspension loaded.
Check out my webpage for great pics and descriptions of my recent suspension rebuild and 1LE brake upgrade:
http://photos.yahoo.com/taramiller72
Click on first 2 pages.
HTH....
Ed
ModdedNerd
Dec 25, 2014 05:51 PM
FredM
Dec 18, 2014 01:40 PM
Dec 1, 2014 08:08 AM
thenewkid
Nov 27, 2014 09:41 AM
USAirman93
Nov 24, 2014 03:37 PM
