Arg... SLP way to much, other headers that are great?
Old Sep 3, 2002 | 09:59 PM
OutLaw305's Avatar
Post Arg... SLP way to much, other headers that are great?
Dang SLP's ... running up into 6 - 7 hundred. Bah ! So what else would be a good header to buy? Im looking to put them on my 305 right now, but transfer onto a 350 thats been bored over to a 383. Will i have a problem with all the extra cubic inches for the headers on the 305? Or will they work fine for both applications?
~ White 92 Camaro Rs 305
~ Flowmasters
~ K&N Filtercharged
~ 383 Build up in the near future
Old Sep 3, 2002 | 10:56 PM
85_tpi_350's Avatar
Cool
Go to www.summitracing.com and order a free, home-delivered catalog. They have quality headers from several different companies to fit Camaros; Hedman, Hooker, Edelbrock, Dynomax (maybe) to name a few. Pick your favorite, pick up the phone and call. They may run $200-$300, but hey, it beats $600-$700 for the SLP stuff. It is ridiculously expensive, isn't it? Also, Summit is the place to go to get other go-fast parts at a really decent rate. I am shocked and amazed that more people on this site don't list them as a good source. They're the bomb-diggety for any hard-core buildup.
Horsepower is like cheese, you can add it to ANYTHING and it's a little more enjoyable.
-Posey
Old Sep 3, 2002 | 11:22 PM
Chode89's Avatar
Post
Headers that work well on your 305 are going to be too small for your 383. Get a good header with a 1 3/4 primary for your 383. Full lengths will make more power but become more work and cost when you are doing the rest of the exhaust. I had SLP's and they are a great header, look for a used set nothing can really go bad with them and the wall thickness on the tubes make them really quiet.
Old Sep 4, 2002 | 02:02 AM
mr diabolical's Avatar
Post
nonsense. hedman longtubes, summit part number HED-68460, are longtubes with 1 5/8 primaries which is more than enough for a 305 and will increase power, and they have 3 inch collectors. i wouldnt hesitate for a second to throw these long tubes on a 305, 350, or 383. they will increase power incredibly over stock manifolds in all cases.
and get this....they are about $105 bucks plus shipping. cant beat it.
[This message has been edited by mr diabolical (edited September 04, 2002).]
Old Sep 4, 2002 | 09:18 AM
Chode89's Avatar
Post
1 5/8 primary on a 383 with a good top end? Do the research. (Usually you get what you pay for with headers)
Old Sep 4, 2002 | 09:25 AM
RedIrocZ-28's Avatar
Post
OHH Come on guys, $600-$700?!?! What the hell are you looking at?
I got my SLP 1 3/4" headers WITH the Y-pipe for $382 including shipping RIGHT TO MY DOOR.
Part #:30005
For your 305, and you live in Michigan so I know you don't need the emissions crap, your part number is 30004.They are $399.99 as of right now according to my SLP catalog. This is a far cry from $600. Get the SLP's, mine haven't even begun to show any signs of rust yet...They are the best for a reason.
-Brad C?
355ci '89 Iroc-Z Red, T-tops, power everything, A4,New 10 bolt w/ 3.73's
Trans-Go shift kit Corvette Servo,Accel 8.8mm wires,Flowmaster 80 series ,K&N's, !MAF Screens, Hollowed out airboxes,homemade Subframes. Kieth Black pistons 10.3:1, Comp Cams 270H (.495/.502 218*/224* 110*LSA) & valve springs, SLP 1 3/4" headers, TCI 2400 stall, Dual Roller timing chain, 2 3/4" I-pipe.
Full street trim best run:14.799/mph:93/60': 2.02 (last year) New Times to come.
New times: 13.732 @ 99.30 on a 1.878 60'
Pics of the Iroc
Old Sep 4, 2002 | 10:04 AM
Stephen 87 IROC's Avatar
Post
I ran Hedman long tubes 1 5/8" on my car when I had a 383. I was running high 11's at 117 mph.
Bigger is not always better. A 1 3/4" primary tube on a SBC is huge even for a 383. Many people who run the 1 3/4" headers on a street vehicle would see an improvment in performance if they installed 1 5/8" headers. Maybe if you were running a 406 constantly shifting at 6000+ rpm would you really need 1 3/4" headers. Just don't buy tiny 1 1/2" tube headers. Those are way to small. They'll work with a 305 or a 350 that's close to bone stock.
You get what you pay for. Typical mild steel headers may be cheap but will also rot out in about 5 years. You can increase their life by getting them coated. Stainless headers last much longer but also cost a lot more. My truck has Edelbrock 409 stainless headers. Although they turn brown, they're just as good as new and have been on the truck for close to 10 years now.
The other end of the scale is a true race engine. 1 3/4" tube is entry level. You can get 2 1/8" tube SBC headers but you better have a gold card to buy them.
Stephen's racing page
or check out the race car
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.349
Best MPH on a time slip: 119.7
Best corrected ET: 10.983
Altitude corrected rear wheel HP: 480
Best 60 foot: 1.546
Member of the Calgary Drag Racing Association
Old Sep 4, 2002 | 10:16 AM
91RS5speed's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by mr diabolical:
</font>
You have any pictures of these bad buys installed? If so i would love to see them.
http://bitchincamaro.no-ip.com 91 RS Camaro 5-speed black w/t-tops 305 TPI
MODS: SLP cold air intake w/K&N, air foil,Accel 19 LB injectors, March aluminum under drive pullies, Alburn pro posi, Aluminum drive shaft, Random Technology 3'' cat-back, 8.5mm MSD wires, 160 thermo, jet fan swich, Custom chip with 91 vette computer, SSBC slotted rotors, optima battery in the rear, BMR adjustable lower control arms and panhard rod, Kenny Brown strut tower brace, TB bypass, no egr, no air
Old Sep 4, 2002 | 10:41 AM
Chuck!'s Avatar
Post
I got the Hooker 2055's (air and y-pipe) for $312 from Summit after 10% off. 1 5/8" primary, 3" y-pipe. Fit well, plug access sucks though.
Old Sep 4, 2002 | 08:56 PM
boneheadzz's Avatar
Post
edelbrock makes headers #6872 that are coated for $340 in the jegs catalog.
[This message has been edited by boneheadzz (edited September 04, 2002).]
Old Sep 4, 2002 | 10:54 PM
89WS6L98's Avatar
Question
<font face="Verdana, Arial" size="2">Originally posted by Chuck!:
I got the Hooker 2055's (air and y-pipe) for $312 from Summit after 10% off. 1 5/8" primary, 3" y-pipe. Fit well, plug access sucks though.</font>
Chuck: How can one get 10% off when ordering from Summit?
Old Sep 4, 2002 | 11:58 PM
Chuck!'s Avatar
Post
They have codes out there occasionally, I think there's a topic in the lounge lookin for the code... but I went to there (Ohio!) during their Summit Super X weekend and everything waas 10% off Saved like 60 bones!
RUENUF
May 25, 2016 08:10 PM
novaiiman
May 15, 2016 11:36 AM
RUENUF
Mar 13, 2016 03:39 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
