will a comp cam 305 from an LT1 work in a L98 TPI
Old Aug 28, 2002 | 05:35 AM
john-e-boy's Avatar
Post will a comp cam 305 from an LT1 work in a L98 TPI
I have a CC 305 for an LT1 that I wont be using and was wondering if it would work in my 350 TPI engine?
John
Old Aug 28, 2002 | 10:06 AM
IROC5.7TPI's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by john-e-boy:
John
</font>
It will physically fit if you push in the dowel pin, but the cam is the wrong power range for a L98 with a long tube runner intake. That cam will make power all the way up to 6500RPM, but the stock TPI induction components will limit airflow and crap out at 5000rpm. Not a worthy mod in my opinion. I would sell the cam and buy something more suited for the L98.
Mike L.
1987 IROC Z 5.7 TPI A4 3.27 Borg-Warner four wheel disc
Mods:
2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified airbox w/ K&N's, Relocated MAT sensor, Gutted MAF, 160* thermostat, MSD 6A, Accel 8mm Wires, bypassed TB coolant, 3" Flowmaster 3 chamber single outlet, custom adjustable cutout, 3" MAC mandrel intermediate, airfoil, ported plenum. !smog, Crane AFPR, Accel rail mounted FP gauge, Harlan shiftlite, 24lb. injectors, Hedman headers, a few others I forgot...??? FINALLY GOT PAINT!!
Check out my IROC webpage!
Old Aug 28, 2002 | 11:11 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Post
You cant push in the dowel pin, you need to cut it to the correct length.
You're right in saying that cam is too big for a stock TPI car. But for one with great heads and an upgraded intake manifold, it'll work nicely.
1991 Camaro Z28
350 L98 w/ T56 (originally 305 LB9 w/ T5)
318 RWHP, 419 RWTQ
12.803 @ 108.50 MPH (1.932 60')
Member: SoCal F-Bodies
ThirdGen 4-Life!
Old Feb 9, 2003 | 04:43 PM
89-WS6-GTA's Avatar
Why does it have a dowel pin didn't most LT1 up til '96 not require a dowel pin. But from what ive seen and read the CC 305 will work fine in an L98. However like someone said things will have to change. LTR blows, you will need and aftermarket intake, Super, Mini, Stealth Rams, or LT1, They all can breathe to atleast 6500RPM. Also you have to replace the springs. and i seriously hope you have some work done to those L98 heads!!
Old Feb 9, 2003 | 04:47 PM
89-WS6-GTA's Avatar
Hey Kevin91Z what type of work did you get done you your ZZ3 heads? Thats a nice car!!
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
alliance12364
Mar 6, 2015 04:39 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Elcojoe
Nov 17, 2014 10:27 PM
