6 rib belt on an 8 or 12 rib ATI pulley??
Old Oct 7, 2005 | 03:21 PM
onlyone07's Avatar
Anyone ever hear or do this? I was wondering if it's possible to do or if the belt would jump ribs? I think I have an 8 or 10 rib belt and a 12 rib pulley. I need some info on what to do with this. Should I spend the money on the correct pullies or would running a smaller ribbed belt on a larger ribbed pulley be fine?
TIA,
Wade
Old Oct 7, 2005 | 03:31 PM
Sparkz28ss's Avatar
Re: 6 rib belt on an 8 or 12 rib ATI pulley??
I had two 4 ribs on a 8 rib setup for a while....worked fine...I just made sure the two belts where from the same batch...
it will work...it should not jump....but belt slip my be a problem
Old Oct 7, 2005 | 04:23 PM
markinkc69z's Avatar
It should work just fine.
Old Oct 7, 2005 | 06:16 PM
onlyone07's Avatar
Thanks guys.
Old Oct 7, 2005 | 11:21 PM
Ponyhntr's Avatar
Yep, it works....I'm running a 12 rib crank pulley with a 8 rib belt and blower pulley. No problems at all.
Old Oct 10, 2005 | 08:31 PM
ZBLKHELLRZR's Avatar
So what is the preference? 8 rib or 12 rib pulley system? That's my dilema. 14psi is the target for my application.
Thanks!
Old Oct 10, 2005 | 09:14 PM
Ponyhntr's Avatar
Thanks!
The more ribs the better....less chance of having belt slip problems.
Old Oct 10, 2005 | 09:44 PM
onlyone07's Avatar
Do the larger ribbed pullies put more stress on the crank snout?
Old Oct 10, 2005 | 11:37 PM
Good question! Didn't even think about that. Maybe Mark or someone else can chime in on that.
Old Oct 10, 2005 | 11:53 PM
In theory the more ribs the less stress you will have because the adjustment doesn't have to be so stout. With spring loaded idlers the loads are safe for bearing life, but the increased surface area of the wider belt is obviously an advantage with high boost, precisely why people step up to the wider drive.
Old Oct 11, 2005 | 03:30 PM
onlyone07's Avatar
Thanks Mark!
bunker
Jan 30, 2016 08:09 PM
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
