Suggest a Keyed Hub
Old Sep 28, 2005 | 09:02 PM
SprayedZ28's Avatar
Suggest a Keyed Hub
Ive got a 383 LT1, Eagle 4340 crank. The motor has an ATI D1 on it. I deff need to put a keyed hub on, but dont want to have to pull the motor back apart to do anything special to the crank.
What keyed hubs will work on this crank with the best results. BTW, Im trying not to spend 500 bucks on the ATI one.
Old Sep 28, 2005 | 09:46 PM
97WS6Pilot's Avatar
Re: Suggest a Keyed Hub
I just used the stock hub. Took it and the crank to a machine shop and had them cut it into the hub and crank. I think it only costed like $30. I don't know if your eagle crank is any different. Wouldn't think so though.
Old Sep 28, 2005 | 10:34 PM
breakmyfootoff's Avatar
The snout on the eagle crank should aready have a keyway cut into it, you just need to take the hub to a machine shop to have the key way cut into it, or you can just buy a keyed hub from www.thunderracing.com .
Old Sep 28, 2005 | 11:05 PM
PWRMAD95's Avatar
ASP makes the strongest stock style hub.
$90, I believe.
Machined stock hubs are weakened when they're slotted.
Old Sep 29, 2005 | 02:01 AM
1995ta's Avatar
Where can you get an ASP hub?
Old Sep 29, 2005 | 09:56 AM
97WS6Pilot's Avatar
I wouldn't waste your money on an ASP hub or pulley the stock one is strong enough. Provided you have it keyed. Spend the money you saved on a good dyno tune when you get it all together.
Old Sep 29, 2005 | 10:40 AM
speedmiser's Avatar
I've had very good dealings with Thunder Racing, EXCEPT when it comes to the double keyed hub I bought from them. Machine work was very sloppy - I was very dissapointed to see something that bad, come from a company that I'd had such good experiences with in the past. I realize they farm this work out - but it still reflects poorly on Thunder. My engine builder said he could clean it up and use it (which we are doing), but had I known what I was getting before I ordered, I would have definitely went with the billet single keyed piece from ASP. Price is about the same as the single keyed stock piece from Thunder, and you don't have to ship ASP your stock core.
Old Sep 29, 2005 | 02:25 PM
1995ta's Avatar
Exactly. I'm not cutting any corners on my project so getting a "sloppy" hub is not acceptable. I am getting only the best parts so I dont mind spending a little more on an ASP one.
...so once again, where can I find an ASP hub?
Old Sep 29, 2005 | 03:57 PM
speedmiser's Avatar
You can order from ASP directly
http://www.aspracing.com/frame.htm
I don't think the hub is listed on their site though - you'll need to call them to order 1-877-928-8678 - make sure you specify year model.
1996LT1Z28
Apr 14, 2015 07:15 PM
moparman
Mar 5, 2015 08:47 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
