Methanol questions
Old Oct 10, 2005 | 05:11 PM
mw's Avatar
mw
Methanol questions
Trying to find an intercooler for a p600b that fits well and reasonablely priced but I'm considering just going with methanol/water alone.
I've got a vortech elbow that’s divided so if the nozzle is put after the maf (planning to put it in stock position) I think I would need two for distribution purposes. Would it be ok to spray before the maf sensor? The kit I was looking at has pressure sensors to detect a clogged nozzle and I don't think it would work properly with two nozzles. Just don't want to screw up the maf sensor.
Old Oct 10, 2005 | 06:31 PM
speedmiser's Avatar
Re: Methanol questions
You can always remove the divider from the vortech elbow - that's what I did. Wasn't quick or easy though - used a sawzall and good sized dremel. You could take and easier approach and just buy the Trick Flow elbow.
Old Oct 10, 2005 | 08:50 PM
boosted-lt1's Avatar
I wouldn't spray before the MAF. I wouldn't want ANY amount of liquid associated with electronics.
You may have to at least notch the divider a bit if you can't get the nozzle back about 1 inch or more. Thats just an opinion though.
-Scott.
Old Oct 10, 2005 | 09:27 PM
mw's Avatar
mw
Sounds like it would be better to forget about the pressure sensors (which would make it cost less anyway) and just use two nozzles so distrubution might improve. Thanks.
Old Oct 11, 2005 | 12:10 AM
Alvin@pcmforless.com's Avatar
Unless your doing some really wild things a simple boost switch to arm the kit is all you really need.
I'm spraying my alky in the section of pipe right before the vortech elbow. My car is speed density though.. I have no idea if thats where your MAF is or if its in the inlet elbow.
Old Oct 11, 2005 | 08:37 AM
mw's Avatar
mw
It's not anywhere yet ,still trying to gather parts to put it together. plans are to put it right before the elbow on the pressure side. I've been looking at a dual stage kit from this place.
http://www.enginerunup.com/level_3_dual_stage_kits.htm
Old Oct 13, 2005 | 10:30 PM
mw's Avatar
mw
Ok, here's a couple more
How will using methanol affect wideband readings if at all?
If a car is tuned without metanol will using it make you rich, lean, what effects will it have?
95maroboi
Jun 7, 2015 12:18 PM
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
