Running Lean
Old Sep 6, 2005 | 12:47 PM
RICEFEDZ28's Avatar
Running Lean
Running lean after the car has warmed up maybe a half hour of driving. What should I check?
Old Sep 6, 2005 | 12:52 PM
NYSS Guy's Avatar
Re: Running Lean
Do you have any tuning programs? Is it lean at WOT, or at idle? Need way more details to help.
Old Sep 6, 2005 | 02:27 PM
RICEFEDZ28's Avatar
Re: Running Lean
Runs Lean At Idle And No Programs.
Old Sep 6, 2005 | 10:12 PM
NYSS Guy's Avatar
Re: Running Lean
how do you know it's lean at an idle? Has the car been tuned by anyone? If it is indeed lean at an idle, you may have a faulty o2 sensor. What year is the car?
Old Sep 7, 2005 | 06:44 AM
RICEFEDZ28's Avatar
Re: Running Lean
The car is a 96 Z28. No fine tuning. I have a 224/230 cam all the bolt ons and an s trim supercharger. I put the supercharger on about 3 weeks ago. It ran fine for a while. Just this weekend the engine light came on so I scaned it. The code was a P0174 and a P0172. I monitored the 02's with the scanner the both read .06v. Is it possible that the boost caused an intake leak? The 02's only read lean at idle.
Old Sep 7, 2005 | 08:01 AM
NYSS Guy's Avatar
Re: Running Lean
If you are looking at narrowband o2's they are not gonna read right. At an idle they should be bouncing all over the place. Either get a wideband, or see what the o2 are reading at WOT. The car definitely is gonna need to be tuned though with your setup. Although I'm not as familiar with tuning LT1's.
grabbem88
Feb 13, 2015 03:09 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
TechCam97
Sep 12, 2002 07:20 PM
