putting a walbro 255 in--has a trex inline assistor...
Old Sep 27, 2005 | 05:29 PM
glennxx1's Avatar
pump, will the inline helper pump hurt my walbro's lph? if so when i take off the trexy would i need to run new line all teh way up sense theres a gap or could i just use some kind of high pressure line to connect the two?
Old Sep 28, 2005 | 06:39 AM
glennxx1's Avatar
Re: putting a walbro 255 in--has a trex inline assistor...
any1?
Old Sep 28, 2005 | 04:16 PM
97WS6SCharged's Avatar
You can get high pressure line and fittings from any Autozone, Advance, etc... Make sure you specify what it's for though. Just remove the T-rex and put it on eBay.
Old Sep 28, 2005 | 05:30 PM
OBE1 95Z28's Avatar
The TRex will act as a restriction, remove it. Check the length of fuel line on your TRex installation. The Vortech instructions have you loop the fuel line when installing the TRex so you end up having plently of line to delete the pump. Buy a brass barb fitting to reconnect the lines and pre-heat the fitting to 400 degrees prior to insertion to melt it into the stock plastic line.
Old Sep 30, 2005 | 09:28 AM
97WS6Pilot's Avatar
The flow numbers on the TREX are pretty good. If you are using the FMU or adjustable fuel pressure regular setup I would keep it in there. If you have stock fuel pressure I would remove it. It becomes useful when your trying to get good flow at higher pressures than stock.
If you are in doubt, scan the Wide Open Throttle O2 sensor before and after removal of TREX. Which ever setup gives you the highest O2 sensor reading will also give you the most fuel.
HarleyZ28
Oct 5, 2015 06:23 AM
kaoticcamaross
Feb 17, 2015 03:13 PM
ChameleonGreen
Sep 2, 2002 05:15 AM
Skull Leader
Aug 10, 2002 11:01 AM
