can i regulate down a fuel injected pump to run a carb
planning on running a P1SC blowthrough set-up.alreadt have a areomotive A1000 pump can i regulate it down to run the carb. car craft did something in there lastes issue, but no info on the pump they used just the regulator.
thanks.
thanks.
Re: can i regulate down a fuel injected pump to run a carb
I've done this before. You have to use a bypass-style regulator on the return line, with the return line tee'd into the feed line. Worked like a charm. The plus is that the pump will handle more hp at the lower pressure.
thanks guys,thats what i'll do.
engineermike:so on the return line you would t' it back into the feed line and not back to the tank it's self like on most return style fuel systems? if so that would make things easier for me.
thanks,
johnny
thanks,
johnny
No, you still have to run it back to the tank. What I'm saying is that the return line should "t" into the main feed line, go through the regulator, then back to the tank.
Jul 4, 2005 05:00 PM
