conversion
Old Sep 8, 2005 | 07:14 AM
realslow94z28's Avatar
conversion
can anyone convert this to standard 68kg/sec. flow rate on holeset hy35
Old Sep 8, 2005 | 07:31 AM
SMOKNZ's Avatar
Re: conversion
You want it in lbs/min or cfm?
Old Sep 8, 2005 | 07:28 PM
Re: conversion
Either One Will Do. Thanks
Old Sep 8, 2005 | 08:16 PM
TA_LT1's Avatar
Re: conversion
The HY35W is right for a 4cyl. I had a turbo 2.3L Mustang with that turbo. Some stock 5.0's can make close to 400 with them. I think they're too small for an LT1, unless you went with twins.
Old Sep 9, 2005 | 08:39 AM
SMOKNZ's Avatar
Re: conversion
68kg/sec = 8994.7 lbs/min No turbo I know of smaller than a house will flow that much air. Are you sure about the units... even if it would be Kg/min, it's 149 lbs/min, and that is alot of air for a turbo that's on a 4 banger. Thats more (WAY MORE) than a T-76, and you will probably never see one of those on a four cylinder. All I used is 1 lb = .4536 Kg, and converted sec's to mins.
Old Sep 9, 2005 | 10:59 AM
Re: conversion
i found out that it flow 800 cfms @ 3.0pr, and 700cfms @ 2.0pr. thanks for your help.
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
tdigger9899
Sep 7, 2015 10:56 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
