cone filter size?
Old Nov 1, 2005 | 08:24 PM
flusz28's Avatar
cone filter size?
what size cone filters is everyone running on there blown cars? i think mine is 6-9inches long and 3.5inlet for the pipes to connect up too. would it do anything if i went bigger?
Old Nov 1, 2005 | 09:00 PM
97WS6Pilot's Avatar
Re: cone filter size?
9" with a 3.5 opening. 7" is stock on Procharger Kits. I wondered if I should go smaller to help create vacuum in the intake tube. Don't know if it will fit the s-trim intake.
Old Nov 1, 2005 | 10:38 PM
Lonnie Pavtis's Avatar
Put the biggest filter on that will fit. Any restriction here will significantly limit your boost. Also look at the Green filters, they have a slightly stiffer construction & seem to resist collapsing better than the K&N.
Old Nov 2, 2005 | 06:28 AM
flusz28's Avatar
only thing is when you go longer won't that increase the inside diamater? it would be hard to find something to connect the filter to then.
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
floorpedal1
Sep 10, 2002 06:09 PM
x7x7
Aug 15, 2002 06:49 PM
