cogged pulleys with S-trim?
I've heard from Vortech that it's unsafe (for the head unit) to run cogged pulleys with the non-Heavy Duty S-trim. They said that some S-trims were HD versions, and would be fine to use with cogged pulleys.
Has anyone run a non-HD S-trim with cogged pulleys?
Any reliability issues?
Thanks.
Raymond
Thanks.
Raymond
Re: cogged pulleys with S-trim?
Originally Posted by 96speed
If Vortech says not to, why would you chance if regardless even if one or two people had luck? Seems foolish, IMO.
Ryan
Ryan
Raymond
I am doing it. My pulley system still uses the spring style tensioner, so there is no extra pressure from the belt being too tight. Also I dont drive my car so a long life is not an issue with me.
Cogged belts and a street setup are a poor mix. It is difficult to get good belt life out of a motor that is constantly going from open to closed throttle. Tends to strip the teeth off the belt. Not to mention that it's hard on the blower. Also, there is no need for a cogged belt.
Rich
Rich
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
