cam motions recommendation for my car hyd roller
im thinking of sticking with a hyd. roller...heres what cam motion recommended...what do you think?
twin turbo lt1, 1 5/8 turbo headers, MP t-70 turbos, 20-22 psi on race gas, 6 speed, 3800 lbs, shooting for mid/low 9's, street/strip car
Grind Number X2341-2341-14+2
Duration (intake/exaust) 234/234
Lift (intake/exaust) .576/.576
Lobe Center Separation 114
Intake Centerline 112
Re: cam motions recommendation for my car hyd roller
I'm not sure how the MP T-70 turbos compare to equivalent singles. . . but the cam sounds good. If the turbo's limit you to ~1000 rwhp, then the cam might be on the big side.
Try giving somone experience with turbo cams a call, Ken Duttweiler is a friendly guy to start with. A cam is where a lot of the magic happens so take your time
I'm not a big fan of Cam Motion (aka: Slow Motion). They don't own a dyno, Spinmaster, nor are there many turbo motors in the area to play with. I'm also not a big fan of their popular reverse-split turbo cams. However, the single pattern they recommended for you looks pretty good.
oldschool
Feb 9, 2016 09:21 PM
