My new turbo set up...
Old Aug 20, 2005 | 11:04 PM
wingnut's Avatar
See my sig for some updated pics. TB91 large frame with 1.14 ar. Still tunning and fixing odd problems...will get better pics out later. Does not spool up as fast as the t88, but but does pull hard under boost.
Wingnut
Old Aug 20, 2005 | 11:20 PM
ss#1230's Avatar
Re: My new turbo set up...
thats the biggest turbo ive ever seen on a LT1 or LS1 by far! it a friggin monster!
i wish i had a LT1 that could take that kinda punishment!!!!!!
oh, btw, where is your radiator? doesnt look like you have room for one.
Old Aug 21, 2005 | 01:34 AM
breakmyfootoff's Avatar
Holy Sh*t!
Old Aug 21, 2005 | 01:50 AM
97WS6SCharged's Avatar
The radiator looks to be sitting in front of the core support.
BTW, you're one sick puppy. I love it.
Old Aug 21, 2005 | 07:35 AM
MEAN LT1's Avatar
Thats a big flipin Turbo. Holy Shizzle
Old Aug 21, 2005 | 08:00 AM
bad93z's Avatar
Nice setup
are those truck headers you used? I only ask because they look ALOT like the headers on my 88 fullsize
Old Aug 21, 2005 | 09:58 AM
wingnut's Avatar
Originally Posted by bad93z
Nice setup
Good Eye..I had some blazer v-8 headers made out of stainless and then welded some stainless 3" v flanges on them, put them on backwards and bam! Headers I can take off and on in 10 minutes with out even removing the dip-stick.
Car has good street manors and is a little slow on spool up (needs more rpm,s). But at thirty PSI WOW!!! I will get some dyno numbers this week if i get things fixed.
P.S. the radiator is sitting in front of the the factory core support with a pusher fan.
Old Aug 21, 2005 | 08:21 PM
bad93z's Avatar
You may have just made my turbo setup fabrication easier
If you don't mind my asking, where'd you get the v-clamps?
Old Aug 22, 2005 | 03:23 AM
5.0THIS's Avatar
30 psi through that turbo? That's moving alot of air... what kind of numbers are you predicting?
Old Aug 22, 2005 | 02:29 PM
96PTKZ28's Avatar
Sweet turbo. Im just wondering how bad the lag will be. Is this the first attempt at this large frame?? Probably wouldnt be the most street friendly beast, but on the other hand right at home on the 1/4 mile!
Old Aug 22, 2005 | 02:34 PM
FutureZMan's Avatar
Wingnut
I love you...
Whats the spec on the turbos? Maybe i didnt catch it, ill look again.
Old Aug 22, 2005 | 04:08 PM
wingnut's Avatar
Originally Posted by FutureZMan
I love you...
Burns stainless has some good stainless v-clamp sets and so does www.turboneticsinc.com
If my converter was not so loose, lag would be unbarable. However, with a 4000 rpm stall, you get off of the line and watch the bike go ahead of you for about a sec then everything gets blury and you just hang on. A little soft on takeoff. I thought about using NOS and have my DFI 7 turn it on until positive map pressure is present then all turbo after that.
I changed and went with a tb-91 big frame turbo and now have the 1.00 a/r turbine housing. I am going to order a .96 and try that too - housings are cheep!
I am looking for about 1000RWHP on race gas. Past that I will be happy.
Wingnut
Old Aug 22, 2005 | 06:58 PM
96PTKZ28's Avatar
How did the T-88 compare to this 91 you have now. I have seen one guy put down 1012RWHP with a PTK kit on a 355 LT-1 and ran 9's. I opted for the 76GTS and have been told that I should expect about 900+. I will also be utilzing a snow meth kit and liquid 2 air intercooler. The a/r on the 76 is 96. Should have no lag problems with that. I was going to go with the 88 but I don't like the idea of more lag. But there is no denying big turbos look COOL!
Old Aug 22, 2005 | 07:16 PM
wingnut's Avatar
The 91 I have now is a true 91mm while the t-88 i had before was an outlaw t-76 moded to t-88 wheel (small frame turbo). I can say I have lots more lag, but a positive man to intake pressure ratio up to 28 to 32 psi. That in itself is worth a lot. As for street fun, the t-88 was more fun as I did not have to down shift out of 3rd for boost at low speed. Now I have to have the rps's up. I do not however, want a dyno queen, that is why I am going to buy another turbine housing if the lag is to much at the track.
I guess I could always be like the supra guys and want to race from a roll
It feels good from a takeoff, it just does not pull the wheels without the trans break. I always foot launch anyways.
I will do some tunning and I bet I can remove some of that lag without NOS.
Wingnut
Old Aug 22, 2005 | 11:01 PM
5.0THIS's Avatar
How much has your boost threshhold changed, if any?
