Need a good head gasket for 14 lbs
Old Aug 26, 2005 | 07:47 PM
wicked_95z's Avatar
I'm looking for a good head gasket for my 383 that will hold 14 lbs from a P-1SC. I did a search but didnt come up with anything useful that I could see. Thanks
Old Aug 27, 2005 | 09:40 AM
breakmyfootoff's Avatar
Re: Need a good head gasket for 14 lbs
Fel-pro 1074 is about the best thing you can get without going to a copper or cometic.
Old Aug 27, 2005 | 11:34 AM
wicked_95z's Avatar
I just want to make sure that I go through this one more time only. If that means copper so be it. Isn't the 1074 the stock replacement? If so that is what I had on there last time, granted my heads were slightly warped but still I want to do this only once.
Old Aug 27, 2005 | 12:02 PM
FutureZMan's Avatar
Do it the right way the first time, go copper.
Old Aug 27, 2005 | 12:19 PM
wicked_95z's Avatar
http://www.jegs.com/cgi-bin/ncommerc...47&prmenbr=361
What do you guys think about this one?
Old Aug 27, 2005 | 05:57 PM
Jeff 96 SS's Avatar
If its a street car don't go copper trust me I know! Go with Cometic if you only want to do it once.
Jeff
96 SS BLOWN
96 TA 396 D1
Old Aug 27, 2005 | 06:03 PM
Z8'S's Avatar
I have always used Felpro 1074 never a problem
Old Aug 27, 2005 | 06:18 PM
Lonnie Pavtis's Avatar
The 1074 is a thinner LT4 style gasket. The stock LT1 gasket is thicker & made of weaker material... do not use these. You should be fine with a 1074 & studs.
You will not see 14# from a P1SC either, unless you have stock heads & a small cam. Expect more like 10-11# max.
Old Aug 27, 2005 | 08:05 PM
rskrause's Avatar
Moderator
Avoid copper on a street car - they almost always seep. FelPro 1074 would be fine. The Cometic is an excellent gasket but to work properly the correct preparation of the head and block deck is essential - they must be straight, flat, and very smooth or the gasket will not seal properly.
Rich
Old Aug 28, 2005 | 07:42 AM
wicked_95z's Avatar
Is that what you use Rich? Would the gasket I posted above be a bad choice? It doesnt seem to be a copper gasket.
Old Aug 28, 2005 | 08:59 AM
rskrause's Avatar
Moderator
I've used both the Cometic and the FelPro. I have not used the Titan gasket. It sounds good, but of course that is their own description. AFAIK they don't make one for the LT1.
Rich
Old Aug 28, 2005 | 11:53 AM
wicked_95z's Avatar
Is the 1074 a stock replacement gasket that is sent with their gasket sets or is it a upgraded gasket? Thanks
Old Aug 28, 2005 | 01:39 PM
Geoff Chadwick's Avatar
FWIW the "stock replacement" LT1 felpro is 9966PT and is $17.97 from advance auto parts.
http://www.partsamerica.com/ProductD...pe=100&ptset=A
The 1074 OTOH is listed as "high performance" and will set you back $46.46 from advance auto parts.
http://www.partsamerica.com/ProductD...artnumber=1074
The Cometic gasket I have heard wonderful things about when done right, but again - prep is key. If you search you will find that people have leaking problems because of the final surface finish of the head/block surfaces. If done right the Cometic will hold, but if its not right you are in for headaches for a while.
No matter which you do though, good studs will make a huge difference. Some have stuck with bolts and paid the price, despite everything else done properly.
Old Aug 28, 2005 | 03:04 PM
FutureZMan's Avatar
Rich
I never had any issues with my copper, but i have heard of some. Guess i got lucky
Old Aug 28, 2005 | 03:27 PM
SloLt1Z's Avatar
I use 1074's with studs with 15 psi and i have no problem with head gaskets.
