Where do you have your plugs gapped?
Re: Where do you have your plugs gapped?
I run NGK BPR8ES plugs in my AFR heads. I have them gapped at .035 as well. The TR6 is only a half a heat range cooler than a stock plug. Personally I've used the TR6, but I'd go a little cooler. Try the NGK BPR7EFS. Its made for your tapered spark plug hole in the stock head.
