ATI Damper with SuperCharger
I have a supercharged LT1 with the factory damper/hub. I'd like to upgrade to an ATI damper and keyed hub assembly for use with my supercharger.
Is this a custom order piece and where should I buy one? I'm a bit confused as to what I need and how it all fits together.
Thanks.
Thanks.
Re: ATI Damper with SuperCharger
you can get on directly from ATI or even jegs sells them. About $400. If you have a Procharger you will have to machine the spacer or shim the blower bracket out to get the pulleys to align
For some reason I thought this was a custom piece. Any way, you mean that the piece needs a spacer to bring it out further to line up with the supercharger or that it needs to be machined slightly shorter.
Thanks.
Or that I just have to measure and check to see which may be needed.
Thanks.
