rear end
Old Mar 24, 2008 | 04:08 PM
chevycamaro210's Avatar
rear end
hey everyone i just wanted to ask if anyone knew what size gears does a 1997 3.8 camaro have. because i wanted to upgrade mine what size do you think would go good for a street car but will make a good upgrade.
Old Mar 24, 2008 | 06:14 PM
2000GTP's Avatar
GU2 : AXLE REAR, 2.73 RATIO
GU4 : AXLE REAR, 3.08 RATIO (V6)
GU5 : AXLE REAR, 3.23 RATIO
GU6 : AXLE REAR, 3.42 RATIO
Check your RPO codes in the door jamb or glove box.
Old Mar 25, 2008 | 11:10 PM
it says gu5 so what would be a good upgrade and what kinda improvment will i be able to see.
Old Mar 26, 2008 | 10:41 AM
mike mlodecki's Avatar
im pretty sure u have 2.73 gears..i got my own personaly mechanic and was asking him wat gears to put into the car cuz i got a 99 v6 fb and he said to be on the safe side but 3.42 gears in it which are from the ls1 manual trans ams.
Old Mar 26, 2008 | 01:16 PM
2001NBMZ28's Avatar
GU5 for sure? Is it an A4? See if you have RPO G80.
Old Mar 26, 2008 | 06:18 PM
These Are All The Codes On The Door Ah3 Ak5 Ar9 B35 B84 C60 Dl5 D35 Fe9 F41 Gu5 Ipb J41 K68 L36 Mm5 M49 Nf2 Nk3 N92 Qb3 Qea R7a R8t R9w Ste T82 Ub3 Um6 Uq0 V73vk3 Vm3 1ay 1sa 1sz 10q 10u 6gm 7gm 8tb 9tb 92i
Old Mar 27, 2008 | 06:50 PM
GETGONE's Avatar
If the car is an RS(sport appearance package in later years) it got the upgraded 3.23 gears. My 00 V6 just has the 3.08's with an open diff. If I run across a 3.42 from a M6 for a good price I want to swap that in.
Old Mar 28, 2008 | 10:06 AM
no its just a base model not a rs.
Old Mar 28, 2008 | 10:54 PM
so what do yall recommend for an upgrade.
Old Mar 31, 2008 | 12:15 PM
so does anyone have any advice on what i should upgrade to.
Old Apr 1, 2008 | 10:14 PM
they told me to put 3.73's what do you think
Old Apr 2, 2008 | 01:13 PM
Fuel Fire Desire's Avatar
3.73's are kinda big compared to the stock 3.08's. Ill bet your mileage and cruising rpm's will go into the toilet, but you'll feel a big difference.
I thought about changing the ratio on my car when I blew the rear end, but I liked my 30mpg and 1900rpm at 70mph.
Old Apr 2, 2008 | 01:21 PM
well the told me to look at me rpo code on the door to see what i had and it gu5 so arent they 3.23
Old Apr 6, 2008 | 10:49 AM
anyone.
Old Apr 20, 2008 | 03:21 PM
crushedout's Avatar
v6 cars dont come with 2.73's from factory
He has stock 3.23's
yes, this is one of the most common gears in our v6's
You can install 3.42's from a factory F body and just do a whole rear end swap or you can install 3.73's. I would reccommend havingh someone install those for you as they have to be set with in a couple thousands of an inch. Your lucky because you have a 97 and the gears will be tunable in your computer.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
