What would a V6 do with a T/D Exhaust Setup?
Old Aug 14, 2007 | 05:17 PM
Need4Camaro's Avatar
I used to own a few V6's... I'm aiming to put a TD exhaust on my Z28 however I keep wondering how would a TD exhaust system benefit a 3.4 or 3.8L should it have the rest of the bolton mods... (cai / lid, tune, headers. ect)
Would it even sound decent?
Old Aug 15, 2007 | 05:33 PM
93v8clone's Avatar
it would sound like someone fartin on a snaredrum
Old Aug 15, 2007 | 08:51 PM
FunkZ's Avatar
Dual 2½" with an H pipe and Borla XR-1's dumped at the axle on a heads and cam 3.8
http://videos.streetfire.net/search/...9770d16aae.htm
Old Aug 16, 2007 | 09:17 AM
Nice, it would have been smarter to wait for dry roads though... Did that take place in Illinoise? about how much HP is he putting out?
Old Aug 16, 2007 | 07:13 PM
FunkZ's Avatar
Oklahoma I think.
N/A was 208hp/206tq untuned with 3800 stall
http://videos.streetfire.net/video/E...35076FC417.htm
Old Aug 16, 2007 | 08:35 PM
Oklahoma I think.
I see, I like how Divided highways can become freeways - sorry but civil engineering has always fascinated me...
He must have really knew how to put it all to the ground - any suspension mods? stickier tires? or was it the 3800 stall and 3.73's that won the race?
Old Aug 17, 2007 | 06:05 PM
Gotchocmilk39's Avatar
I have T/D on my 2000 v6 camaro. Using stock tubular manifolds (soon to be header in a few weeks if everything goes well) into 2inch H-pipe and right after the Hpipe it turns into 2.25inch piping both pipes going over the pass. side axle. I'm using (2) 2.25inch sweetthunder mufflers also with short (2) 2inch Hi-flow cats. Sound is great when I'm not mashing it and its very loud at any acceleration, I would say normal accelerating is like open headers but cruising is quiet. When i first start it up it lobes nasty then slowly smooths out. Only other mods are lid, filter, slp cai, msd wires, ngk plugs. My first exhaust was all stock but had a 3 inch high flow with a 80 flowmaster but now with my new exhaust I have 100 times better sound and some performance. At first I flet it lost some low end but sence your car retunes itslef every 500 miles or what ever everything sence like I lost non and gained alittle more. The biggest difference is anything after 3k rpms. I dont have any new clips of it after the pipes and everything have been worked in but when the headers get on I will. I just signed up here a few days ago I normaly hang out at camarov6.com
here are some pics and clips:
http://s44.photobucket.com/albums/f1.../True%20Duals/
Old Aug 18, 2007 | 09:08 AM
NemesisLT1's Avatar
^^^ sounds like a honda civic
Old Aug 18, 2007 | 09:12 AM
Nice car! Not too bad on the sound there, it has alittle rumble it when you're not on the gas...
Old Aug 18, 2007 | 11:57 AM
MarcR94v6's Avatar
I don't understand why you would use 2.25 instead of 2.5 inch piping.
Old Aug 19, 2007 | 03:08 PM
becauae 2.25inch flows just a little over a 3 inch catback so really I dont need anything bigger.
Old Aug 20, 2007 | 10:31 PM
bkpliskin's Avatar
Oklahoma I think.
um, no....a heads/cam/exhaust etc etc 3.8L is not putting out 208hp, it's putting out a lot more than that. 3.8L's put out 200hp STOCK. A 208HP camaro is not going to beat an LS1 camaro no matter what stall speed or gears it's running. It was putting out a hell of a lot more than 208hp with all of those mods
Old Aug 21, 2007 | 05:45 PM
Thats because I had 3 leaks by the mufflers and the system was only 3 weeks old. And of course it will that rasp becuase it is a v6.
Old Aug 21, 2007 | 10:37 PM
FunkZ's Avatar
Those figures were quoted directly from the owner, so if you want to argue go talk to him. That 208 is measured at the rear wheels, not the 200 crank hp they have stock - a stock 3.8 puts down around 165 to the rear wheels. Also a high stall converter will significantly reduce the hp measured on a dyno. And finally as I said, the guy stated the dyno was after the heads/cam install but before he got it tuned.
Old Aug 21, 2007 | 11:06 PM
MarcR94v6's Avatar
Where did you get this information?
alex5366
Exhaust System
Mar 8, 2015 11:28 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
alex5366
Feb 17, 2015 08:12 PM
Ken95Z28
Aug 21, 2002 04:32 PM
