Rear wheel bearing -- can I remove the axle myself?
Old Apr 10, 2008 | 07:25 PM
kisk's Avatar
Question Rear wheel bearing -- can I remove the axle myself?
1995 Camaro V6 3.4L
I know I need a bearing 'puller' to get my rear wheel bearing off of my axle, but can I pull the right axle out w/out removing the bearing, or does the bearing block the axle from being pulled out by hand? I'd like to be able to just do this part myself if possible and then take it to a shop and have them pull and put on a new bearing. What's a typical cost to get one pressed on?
Any tips/cautions when doing this procedure myself?
Oh, and what size is the differential pinion shaft bolt? 7.5mm?
Thanks!
Old Apr 19, 2008 | 07:11 AM
kisk's Avatar
kk, I figured it out... just pulled the axle out then used a bearing puller to get the oil seal/bearing out.
Jan 3, 2015 07:22 PM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
blac94Z
Nov 24, 2014 07:12 PM
squarehead
Nov 21, 2014 08:02 PM
