popping sound
Old Jul 17, 2007 | 12:15 PM
Garcia95's Avatar
popping sound
i was driving around a couple of days ago and i floored the gas and there was a pop sound coming out from under the hood any ideas. 95 3.4L
Old Jul 17, 2007 | 01:12 PM
sick94's Avatar
my car does this also, kind of sounds like a backfire back through the air intake.
Old Jul 17, 2007 | 08:29 PM
needforspeedgirl21's Avatar
does yours studder when it goes between 45 and 70 miles an hour
Old Jul 27, 2007 | 01:45 PM
strbcks241's Avatar
Did it sound like directly under the hood? If you were flooring it from a stop and it kinda jerked when it popped, it could easily be the tranny mount(Check the rubber piece between the crossmember and the back of the tranny). If it was under the hood, though, it's probably a problem with the timing(not sure how to check the timing on these, I've mostly worked on older stuff with mechanical/vacuum advance) or a bad fuel mixture( check the inline fuel filter)
Old Jul 28, 2007 | 03:27 PM
Garcia95's Avatar
it came from under the hood thats for sure and well it has no vacume leaks
but the egr is been busted for about 3 weeks now so i was thinking that it might have something to do with it. yes i will change the fuel filter on friday
Old Jul 30, 2007 | 01:34 PM
strbcks241's Avatar
If the EGR valve doesn't open and close right then you'll have problems.
Old Jul 30, 2007 | 03:25 PM
Garcia95's Avatar
i know actually its solenid #3. is there any way to fix it other than buyig a new one cause they run at $219.99. but dosent the egr only give problems in idle, i could be wrong.
Old Jul 30, 2007 | 06:52 PM
2000GTP's Avatar
Maybe try the Parts for Sale forum, see if you can pick up one use. Or you can try a wholesale GM parts dealer such as one of these guys: http://shbox.com/1/4th_gen_tech2.html#Dal_and_Jason
Old Jul 30, 2007 | 07:40 PM
Garcia95's Avatar
thanks man
Old Aug 2, 2007 | 02:21 PM
steelerfan's Avatar
a bad cam lobe or 2 will do that,also
14
Aug 11, 2015 12:03 PM
dolfan324
Jul 17, 2015 10:34 PM
GT what?
Jul 14, 2015 10:17 PM
Noct
Jul 14, 2015 01:18 AM
Boss002
Jul 9, 2015 03:33 PM
