original cam specs of a 95 camaro
Old Nov 26, 2007 | 12:34 PM
Garcia95's Avatar
does any one know what are the specs of the camshaft and the valve terain of a 95 3.4 camaro
thanks
frank
Old Nov 26, 2007 | 06:01 PM
blindxeyed's Avatar
Bore & Stroke: 3.62" x 3.31"
Compression Ratio: 9.0:1
Engine Block: Cast Iron
Camshaft: Hydraulic Flat Tappet Design
Valve Lift (Intake/Exhaust): .427" / .454"
Duration (Intake/Exhaust): 204 / 216 at .050" Lift
Cylinder Heads: Cast Iron
Valve Diameter (Intake/Exhaust): 1.72" / 1.60"
Hope this helps. May be more info that you need, but hey..
Old Nov 28, 2007 | 01:07 PM
Garcia95's Avatar
thanks man
Old Nov 28, 2007 | 07:07 PM
FunkZ's Avatar
Those are NOT the stock cam specs, those are the numbers on the GMPP cam and the Crane 260H.
Here ya go.
http://www.fullthrottlev6.com/forums...ad.php?t=32901
Old Nov 28, 2007 | 07:17 PM
blindxeyed's Avatar
Here ya go.
Alas, someone has lied to me! Thanks Funk, would have hated for that guy to get the wrong info.
Old Nov 30, 2007 | 12:51 AM
Garcia95's Avatar
its cool man its a common mistake
Old Nov 30, 2007 | 06:18 PM
FunkZ's Avatar
Just realized you asked for valvetrain as well. The stock rockers are 1.5 ratio, not sure on the spring rates though.
*Emilia*
May 13, 2015 09:05 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
NewsBot
Dec 3, 2014 12:30 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Queens94z28
Nov 20, 2014 06:03 PM
