v6 problems in friends car..
Old Aug 21, 2007 | 10:43 PM
80TA's Avatar
Buddies car is not running very good. Problem just started happening recently. Car has high mileage about 120,000miles is 95 3.4 v6. Plugs were just changed and wires also. Car is not throwing any check engine lights.
Car is 5 speed. Car starts ok,idle seems ok.But when drive away it seems to have no power,its also is making a lot of vibration that wasn't there before. If you floor it it seems to run not too bad past 3000 or so and will pull to redline pretty good. The problem all seems to be off idle thru the midrange.
I suggested he should change fuel filter, 02 sensors and recheck plugs and wires. I think saw some occasional sparking happening.
The no codes thing is not helping either. I have scantools but not for v6s unless my hptuners can do 95 v6 cars?
Old Aug 22, 2007 | 07:34 AM
FunkZ's Avatar
HP tuners won't work on a 3.4 but a standard scan tool should. Has to be something pretty severe or emissions related to set an SES in the 3.4 so if it's missing the only way to check it is manually. If you suspect misfire run the car at night, you should be able to see spark with the hood open if it's jumping through the wire.
Old Aug 22, 2007 | 08:41 AM
GRNcamaro's Avatar
did you put boush plugs in it? they make 3.4s run like sh*t. if you did take them out and go put in stock ac delcos
Old Aug 22, 2007 | 09:23 AM
80TA's Avatar
Yes they put bosch plus in . What is the stock plug numbers in ac delco or maybe ngk for second choice.
Old Aug 22, 2007 | 10:00 AM
GRNcamaro's Avatar
ill bet money thats what the problem is
Old Aug 29, 2007 | 11:48 PM
chevycamaro210's Avatar
goto autozone if available in your area they will scan it for free maybe someone cut the ses light wires.
Old Aug 30, 2007 | 11:21 PM
Garcia95's Avatar
no they dont scan the 95 only 96 and up ive been to a couple myself and no luck
grabbem88
Apr 16, 2015 06:57 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
StansZ28
Feb 19, 2015 07:39 AM
Dec 5, 2014 11:42 AM
